Tue, Feb 11, 1:02 AM CST
Subject: Issue in Poser
Arah ( ) posted Sat, 16 July 2011 at 3:48 PM · edited Mon, 10 February 2025 at 5:44 PM
I'm having a bit of a problem, every once in a while something weird comes up in poser and i have no idea what's the cause.
I'm working on fixing the gloves for my Elven princess outfit and when ever i bend the hand, some of the mesh stays and drags, usually i can fix it using the joint editor, but it doesn't seem to be working, any ideas what the problem might be? i have the same issues with pants in the groin section too.
Fugazi1968 ( ) posted Sat, 16 July 2011 at 4:31 PM
One of your falloff zones is not big enough to include those vertices that are being left behind.  My method of fixing such things goes like this.
  1. Zero your figure
  2. Select a bodypart and adjest each joint type one by one, resetting the figure as you go.
  3. When you find the joint movement that leaves your vertices behind, select your glove and open the joint editor
  4. Select the joint movement on the joint editor, then select the inner mat sphere.  On it's parameters increase the scale until the vertices pop back into place.
On the 4th part you can eitehr increase the scale all part, or one or more of the x,y,z scales depending on model.
Hope that helps.
John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Arah ( ) posted Sun, 17 July 2011 at 1:50 PM
thank you so much!! it worked!
Fugazi1968 ( ) posted Sun, 17 July 2011 at 3:15 PM
nice one :)
