Tue, Feb 18, 2:34 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: To AprilYSH Eves' eyes in Posette
Grey_cat ( ) posted Mon, 20 August 2001 at 8:55 PM · edited Mon, 25 November 2024 at 5:51 PM
It's unnessary to create new geometry, just redirect your cr2 file to pick up the eyes geometry from Eves object file. See image. In the address area ( first third of the cr2 file) remove the eyes actor defination. Add, after the second path line, a path line for the Eve object, the eyes actor defination lines, and the second Eve path line. This will also work to put Vicki or Mikes head on Possette.
AprilYSH ( ) posted Mon, 20 August 2001 at 10:10 PM
wow, cool, only cr2 editing, no importing objects and stuff! thank you so much! glad you saw my question! i did read the faq in the poser technical forum but it requires renaming the groups in uvmapper to correspond... lalala... got a bit much for me without the apps right in front of me, but THIS i understand without opening one. thanks again Grey cat! :)
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
ScottA ( ) posted Tue, 21 August 2001 at 7:42 AM
No fair! That's cheating ;-) ScottA
AprilYSH ( ) posted Sat, 24 November 2001 at 9:04 PM
by the way, this worked perfectly. i was dubious at first because of the location of the "add this here" section... why would that be straight under the second figureResFile line? it would seem to break the continuity of the figureResFile line for P4NudeWom.obj i decided not to doubt and try it that way first and then try it a different way if it doesn't work. but hey, it worked! now the reason i dug up this tread: this is okay for replacement... how about ADDITION? i'm just curious. just like Traveller's addition to Eve, her ahem genitals - do i just paste that part in a similar manner? i'm gonna give it a go. :) Scott, this could be a great addition to either PoserTech or Poser FAQs? :)
WarriorDL ( ) posted Sat, 24 November 2001 at 9:46 PM
QUOTE: "This will also work to put Vicki or Mikes head on Possette." ...uhhh 'fraid not. Take a look at your neckline if you try that.
