Sun, Feb 16, 6:46 PM CST
Subject: Animated Warfare
gdijedi7 ( ) posted Thu, 28 July 2011 at 8:51 PM · edited Sun, 02 February 2025 at 10:54 PM
So, I'm trying to animate some war sequences, but I can't find any poser smoke for when the guns fire (blood either, but that's another issue). I'd use Photoshop and some of the smoke brushes for that, but I'm wanting to animate, and that's done as a video file, which Photoshop can't mess with.
What can I do?
Medzinatar ( ) posted Thu, 28 July 2011 at 9:24 PM
You might check out Nerd3d's "Smoke and Flames Tool" at DAZ
http://www.daz3d.com/i/shop/itemdetails/?item=10951
there is a video of it capability on that page
KageRyu ( ) posted Thu, 28 July 2011 at 11:05 PM
It's always a good idea to save your animation out as a sequence of frames. Not only will this let you post work the frames more easily, but if the render get's interupted (power failure, computer crash, Poser failure, etc...) you can pick up the render from the frame it left off on and wont lose the entire sequence.
The smoke and flames tool Medzinatar recomended is great, as is that same author's Dust and Trails tool as well as the Spray Tool.  Metaform used to be great for water and liquid effects, but only works in Poser 4-6.  You could try using Particles 3 available at Daz3D for smoke, fire, and other effects.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
rokket ( ) posted Fri, 29 July 2011 at 1:28 AM
Another route is to use real smoke and flames. If you don't mind doing it post, check out Detonation Films dot com. They have a lot of free stuff that is already chroma keyed and works pretty good.
Tashar59 ( ) posted Fri, 29 July 2011 at 9:53 PM
Don't forget Partical Illusion.
gdijedi7 ( ) posted Sat, 30 July 2011 at 2:25 PM
Woot. Thank you.
