Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Quote - Hi all,
A while ago, can't find the thread now, i got some help adding a very simple Python script to jump frames while animating, went like this:
import poser
scene=poser.Scene()
scene.SetFrame(scene.Frame() + 30)
Worked fine in Poser 7, but i've finaly got myself Poser Pro 2010 and while its making the arrowhead on the time line jump, the frame number isnt changing. Anyone know what i'm doing wrong?
thanks.
It works exactly like that. Could it be that your animation is only 30 frames long? In which case the last frame is numbered 29 (they start at 0), and your python would not work.
EDIT: Ah, i see what you mean; right it does not update the counter, hm, never notices this ...
Where is Poser located? I'm asking because I had different Python problems than you had. But the solution was: it had to be in C:ProgramsSmith MicroPoser Pro 2010
When it was in C:ProgramsPoser Pro 2010 I experienced a few Python problems, not with every Python script but with some of them and they worked before in Poser 7 without any problems.
You don't need a new installation for it, just move it.
Quote - its in C:Program FilesSmith MicroPoser Pro 2010 its the 64 bit version i'm using if that makes a difference (i'm on xp 64 bit)..
I'm also on 64 bit but I had the problem when I started with Windows 7, I should have mentioned that. And I forgot that it is called Program Files because I have the German language version (where it is Programme and I translated it to Programs...) :-)
there's no way i can keep the edit keyframes window open, I've tried docking it everywhere i can think of, if i could re-design the window i could but as is there is just not enough space for the document window and the edit keyframes at the same time while animating..
anyone think of any other workarounds to make scene.SetFrame(scene.Frame() + 30) work?
Quote - ... anyone think of any other workarounds to make scene.SetFrame(scene.Frame() + 30) work?
Hm, you could try this method, which does not directly solve the problem, but can work around it (worked for me). It is based on putting the animation palette in it's own (non-dockable window):
1 open the animation palette.
2 create a frame and transfer the animation palette to the frame and execute this (add imports as needed):
am = poser.WxAuiManager ()
animation_pane = am.GetPane ("AnimationPalette")
frm = wx.Frame (am.GetManagedWindow (), size = (200, 200))
frm.Show ()
animation_pane.Reparent (frm)
animation_pane.Window (None)
Now you should be left with the animation palette in a normal (top-level) window, that you can minimize. When you check the "Animation Palette" from Poser's "Window" menu, it might crash.
markschim - setting a variable doesn't work, still not changing the frame. as to why, I'm not so good at math, so i set multiple jumps and just pick one depending on the action that's happening in the animation. it makes things go much faster and smoother.
millighost - not ideal, but probably the best option yet.. I can't believe there is no way to change the frame from python in pro 2010, if it wasn't for the render times I'd prob go back to P7..
I have not tried this specifically as of yet, but there were some cases where the Counter in one window was not updated when modified in another Window. I suspect if you return the focus to the window that is not behaving properly, that it will update the display. In reality, the frames are advancing, just one counter is not reflecting the change.
If you can, please provide details in a report to Support so we can make sure the issue is reported. If you want, send me a Site Mail letting me know the incident number so I can make sure it gets reported. You can put Attn: John in the subject as well.
ratscloset
aka John
Hi all,
import poser
scene=poser.Scene()
thanks.
