Wed, Nov 27, 4:20 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Python in PoserPro 2010 different?
AtelierAriel ( ) posted Thu, 04 August 2011 at 5:33 PM · edited Sat, 23 November 2024 at 8:58 AM
I was using WinXP and Poser 8 and had no trouble loading anything into Poser from external programs such as P3dO and Windows Explorer.
Now I'm up to Win7 64bit and PoserPro 2010 and nothing will load from externals. It's as if there's no communication between the external program and Poser at all.
There must be something with PoserPro that is different from Poser 8 in this respect.
Does anyone have any ideas?
nruddock ( ) posted Thu, 04 August 2011 at 6:48 PM
Quote - It's as if there's no communication between the external program and Poser at all. Does anyone have any ideas?
The communication is done via sockets, so you'll need to check your firewall settings to make sure both programs are allowed.
