Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 6:34 pm)
1 ~ In poser goto file then save ( name it and put it where you can find it ) .
2 ~ with vue open >goto file >new >File >import object>(navigate to where poser file was saved - it'll be a -WhatEverYouNameIt.pz3 ) you'll get an import options dialog click ok .
3 ~ after waiting a lil you'll get another import options dialog choose-(depending on itf you save an animation or still pose ) click ok
if u pick a single frame itll open ...
if you picked animation youll get a warning dialog ... click no
that should get ya going ....
any questions send a message
e-on has several offices, one here in Oregon, that one is open now.
The european offices are on French time (GMT +1 in summer)
There is contact info on their webpage
http://www.e-onsoftware.com/about/?page=2
In Vue's preferences you have to point to a valid Poser installation before you can import Poser files. Vue will ask you to restart the program after succesfull validation.
In Posers preferences you need to switch off "Use binary morph targets". Vue does not like them.
Also Posers standard files in the library are compressed when you install them the first time. Vue does not like them either. If you run into problems you might considder uncompressing them with scripts/utility/uncompressposerfiles in Poser.
Cheers!
How can i import a poser scene to vue?Please be as clear as you can ,i m a rookie in poser.
