Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Hmm... I can get this to work, but it's not additive. When I apply it a second time, nothing happens, so it's just applying pose values.
import poser
scene = poser.Scene()
JumpSize=0.6971784 # in PU
actor= poser.Scene().CurrentActor()
actor.ParameterByCode(poser.kParmCodeXTRAN).SetValue(+JumpSize)
actor.ParameterByCode(poser.kParmCodeYTRAN).SetValue(-JumpSize)
actor.ParameterByCode(poser.kParmCodeZTRAN).SetValue(0)
poser.Scene().DrawAll()
mac
Thanks for replying everyone. I now have this.
import poser
param=actor.ParameterByCode(poser.kParmCodeXTRAN)
param.SetValue(param.Value+JumpSize)
param=actor.ParameterByCode(poser.kParmCodeYTRAN)
param=actor.ParameterByCode(poser.kParmCodeZTRAN)
Which gives me this error message.
Traceback (most recent call last):
File "", line 7, in ?
TypeError: unsupported operand types for +: 'builtin_function_or_method' and 'float
Line 7 is 'param.SetValue(param.Value+JumpSize) '
Have I got this right or not?
mac
In case anyone else might need this in future, here's my final code including rotations. Tested and working.
X channels - positive value
Y channels - negative value
Z channels - no change
JumpSize = 0.6971784 or 170cm - change value to suit.
import poser
RotValue=90
param.SetValue(param.Value()+JumpSize)
param.SetValue(param.Value()-JumpSize)
param.SetValue(param.Value())
param=actor.ParameterByCode(poser.kParmCodeXROT)
param.SetValue(param.Value()+RotValue)
param=actor.ParameterByCode(poser.kParmCodeYROT)
param.SetValue(param.Value()-RotValue)
param=actor.ParameterByCode(poser.kParmCodeZROT)
Thanks again to everyone!
mac
I've searched this forum back to 2004, but can't find an answer.
Problem - I'm making a corridor kit (mostly props) in which pieces need to be moved in increments of 600cm and/or rotated +/- 90 degrees. The problem is that normal pose files are no good because I need the pieces to move 600cm each time the pose is applied (additive) - rather than have them simply moved to that position.
The Daz Studio version uses a set of simple pose scripts for this, but I imagine this can only be done in Poser through python. However, Ockham made a python dialog for me several years ago with a 'Jump' function, so I know it can be done. What I don't know is how to generate a script which can be applied to any prop, BODY or body part with this Jump in it. I also know I can use a .pz2 to call the python script, and that would probably be the best way for the user, rather than have them open the scripts.
Can anyone help out here? A free copy of the product is yours, when it comes out later this month.
TIA
mac
