Fri, Nov 29, 6:46 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 29 1:34 pm)
Subject: Vue unable to locate my plants collection
martial ( ) posted Tue, 09 August 2011 at 5:37 AM · edited Fri, 29 November 2024 at 6:37 PM
Bonjour
I am using Vue infinite 9,5 last version (9505387_Release_3234) on a Windows 7 64 bits system with 8 gigs ram All my vue stuff are in
E:Vue 9,5 infinite
(plants,materials, etc....)
Today during a render Vue crashs around 4 % of rendering( big scene of forest) and freeze my system
I have rebooted and try toload again Vue.It ask me my serial number and after new activation code (ouf this serie of letters)
Ok my Vue finally load and i create a test terrain
When i try to create plants from plants species Vue was unable to locvate it ,searching in C:UsersMartialDocumentsVue 9,5 infinite,,, etc and don't find because my plants folder is inside E:Vue 9,5 infinite
After manually locate some plants i decide to remove all my plants collections and reconstruct them by locating each in E:Vue 9,5 infinitePlants etc
But Vue persiste to try locate it in in C:UsersMartialDocumentsVue 9,5 infinite,,, etc Just before crash ,everything was good and vue locate correctly my collection
But all others collection seems ok : example materials
Is this a way to correct this ??
Must i to reinstall VUE all again (hope not...)
Thanks
bruno021 ( ) posted Tue, 09 August 2011 at 6:13 AM
Do you run Vue as Administrator? In the last tab of the Options panel, you can change the content folder.
martial ( ) posted Tue, 09 August 2011 at 8:38 AM
Gros merci
C'était la solution à mon problème
Thanks again Bruno021
It works ok now
ChuckEvans ( ) posted Tue, 09 August 2011 at 8:51 AM
Ataboy, Bruno ! :)
Renderholic ( ) posted Tue, 09 August 2011 at 9:18 AM
In Poser when you add content or folders Poser automatically updates to show the new content. If I add new content and reorganize my Vue folders is there a way to get Vue to refresh the content folders to show my reorganization?
bruno021 ( ) posted Tue, 09 August 2011 at 9:23 AM
Not until you recreate your collections one by one, unless maybe, but haven't tried, you change the location of the content folder in your Options.
Renderholic ( ) posted Tue, 09 August 2011 at 9:29 AM
Just to be more clear, the problem that I have been having is this. Let's say I have a folder under Atmospheres called Clear Days. Under Clear Days I have two subfolders: Sam's Atmospheres and Bubba's Sunny Days. Now if I add a new subfolder called John's Clear Skies and go into Vue 8 Esprit it does not show under Atmospheres and it asks if I want to locate the folder. I say yes and navigate to the folder on my computer and tell it to add it. Instead of adding it under my Clear Days folder like I have it in my computer, it adds John's Clear Skies as a new folder under Atmospheres which messes up my organization. Is there a way to get Vue to refresh my content folders to show it the way I have it organized on my computer?
Renderholic ( ) posted Tue, 09 August 2011 at 9:38 AM
Bruno, I didn't see your reply until after my second post. I will take a look tonight to see where I have the content folders in options. Maybe if I change that it will solve the problem. Thanks.
bruno021 ( ) posted Tue, 09 August 2011 at 10:44 AM
Yeah, it will never drop the collection where you want it if in a sub-folder, always inside the main folder. But once it's added to the Atmospheres, you can simply drag John's clear skys into the Clear Skies folder.
Trouble ( ) posted Fri, 12 August 2011 at 10:01 PM
I have Vue 9 complete and have no operations tab under options to change my folders because Vue is doing the same thing to me.  I locate my folders and once I close Vue and come back it completely forgets everyone of them.
bruno021 ( ) posted Sat, 13 August 2011 at 2:27 AM
The Operations tab is Inf and xStream only. I don't know how to fix your problem, Cie.
Trouble ( ) posted Sat, 13 August 2011 at 7:26 AM
Thank you any way.
