Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Well, a long time ago I wrote a script to isolate a figure in the scene, an idea I got from watching a friend work in 3ds max, you hit isolate and all other figures and props are hidden, hit it again and they show back, useful for making quick adjustments.
I would like to store the figure state (if it's isolated or not), which figure it is, and a few other options and parameters. I'm storing it in text format right now, but is a clumsy solution, I know there are ways to save this parameters within the poser scene, I've seen it done, just have no clue of how :P
It is possible to store a string in a dial, too.
Maybe a little bit wired, but it works.
<pre style="margin:0;padding:0;font-family:'courier new', courier;">
# Make sure the actor used has at least len(string)/3 vertices.
import poser
TEXTDIAL_HIDDEN = False # set to True to hide text-dials
class TextDial(object):
def __init__(self, actor, dialname, sc=poser.Scene()):
if not isinstance(actor, (poser.ActorType, poser.ParmType)):
raise AttributeError, "Parameter 'actor' must be a Poser Actor"
self.name = dialname
self.actor = actor.InternalName()
p = actor.Parameter(dialname) or self.createDial()
if p:
p.SetMorphTargetDelta(0, 0, 0, 0)
self.parm = p.InternalName()
if TEXTDIAL_HIDDEN:
p.SetHidden(1)
def createDial(self, sc=poser.Scene()):
ac = sc.ActorByInternalName(self.actor)
assert ac
try: parm = ac.SpawnTarget(self.name)
except:
# dialname can not be created or exists but is
# not a TargetGeom as required.
raise Exception, "Ups!"
return parm
def setText(self, text, sc=poser.Scene()):
assert ac
assert isinstance(text, str)
dial = ac.Parameter(self.name) or self.createDial()
assert dial
geom = ac.Geometry()
vcnt = geom.NumVertices()
if (vcnt * 3) < len(text):
raise ValueError, "String '%s' is longer than NumVertices()*3 (%s)" % (text, vcnt * 3)
for entry in range(vcnt):
c = []
for i in range(3):
pos = entry * 3 + i
if pos >= len(text):
c.append(0)
else:
c.append(ord(text[pos]))
dial.SetMorphTargetDelta(entry, *c)
if c[-1] == 0 : break
def getText(self, sc=poser.Scene()):
assert ac
assert dial
c = []
c.extend(map(int, dial.MorphTargetDelta(entry)))
if c[-1] == 0: break
return "".join(map(chr, c[:c.index(0)]))
if __name__ == "__main__":
print "Setting morph-dial 'demo' to a string."
# create class for a dial via TextDial( actor, dialname)
demo = TextDial(poser.Scene().CurrentActor(), "demo")
# set string via setText()
demo.setText("This is a string stored in a Poser-Morphdial")
print "nATTENTION: DON'T USE THIS DIAL AS USUAL! YOUR ACTOR/FIGURE MAY EXPLODE"
# read back via getText()
print "nReading back results in: '%s'" % demo.getText()
print "nIf you save the scene, the string is saved like any other morph."
Hi all,
I've seen several python scripts which seem to store information within the scene, like the script settings, button states, etc.
How can this be achieved? where is the information actually stored? I've seen it in the form of props and such, maybe as parameters? I hope this is not a secret of the trade, as I've seen it so far only in comercial script.
Any pointers are welcome.
