Tue, Jan 21, 11:34 PM CST
Subject: How to handle other formats
Renderholic ( ) posted Mon, 15 August 2011 at 1:11 PM · edited Tue, 21 January 2025 at 11:31 PM
I'm a new Vue user and could use some advice.  I am using Vue 8 Esprit and yesterday I found some great space ship models in Lightwave and Object formats that I would like to use. Will these open directly in Vue or do I need to open them first in Poser and save as PZ3 files?  If they do open directly in Vue should I add them in the same folders with my VOB files or do I need to import them from an outside folder? Will the textures import with the models?
On a related note, I haven't had a chance to look, but does anyone know if Vue includes any outer space atmospheres? I am familiar with using planets, but am not sure how to add stars, constellations, and other background elements.
Rich_Potter ( ) posted Mon, 15 August 2011 at 1:13 PM
you might need to buy an add on package - one of the modules if i recall that will enable you to import objects, im not sure if esprit has this capability or not.
If it does, or you buy the module then you can import .obj and .lwo files and they will work properly.
Chances are if you can import .pz3 files you can import .obj and .lwo as well.
Rich
http://blog.richard-potter.co.uk
Rich_Potter ( ) posted Mon, 15 August 2011 at 1:15 PM
Esprit has the 3d import module already it appears so you should be good to go.
Rich
Renderholic ( ) posted Mon, 15 August 2011 at 1:20 PM
Thanks for fast response! Should I set up an outside folder for these, or do I add them into my regular Vue folders with the VOB files?
Rich_Potter ( ) posted Mon, 15 August 2011 at 1:22 PM
If you want to be organised, then you can have them in your vue folders, I have my own folder system on a seperate hard disk with all my 3d models though, its not quite as strict/mean as poser.
Rich
