Mon, Dec 2, 11:33 PM CST
Subject: Pretty dumb question
Belladzines ( ) posted Wed, 31 August 2011 at 2:10 PM · edited Mon, 02 December 2024 at 11:21 PM
Im trying to re organise my PP2010 runtime ... and make separate runtimes for different things HOWEVER ... when i try to add another runtime (not the main one) it tells me
"this folder doesnt seem to be a runtime folder, please locate ...." blah blah ....
do i put the other named runtimes inside the PP2010 folder or inside the main runtime folder for PP to not have a issue adding them?
thanks in advance ....
JimTS ( ) posted Wed, 31 August 2011 at 2:23 PM
Online Now!
each external runtime has to a"title folder" eg "Barbie stuff" then a Runtime folder in it or poser won't recognize the Add Runtime script/macro
So folder directory would go Barbie/Runtime
                                            Ken/Runtime
                                             Etc
Not Ken Runtime or Barbie Runtime
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Belladzines ( ) posted Wed, 31 August 2011 at 2:37 PM
ahhhh now that explains it ...
thanks!!
Miss Nancy ( ) posted Wed, 31 August 2011 at 2:41 PM
I put the new runtimes in the poser downloads folder. like jim said, the separate runtime goes in a folder with some good keyword or creator name, then ya choose that folder when adding the runtime enclosed in that folder.
Acadia ( ) posted Wed, 31 August 2011 at 3:09 PM
I created an essay on getting organized. Here is the section for runtimes.
**2. Multiple External Runtimes
This is my choice for organizing my installed content.  I did the first method first and it worked for awhile, but as my content grew, it became cumbersome, so I switched to multiple external runtimes, which works out great.
It's really pretty easy.  The problem is that most people over think it.
Just remember that an external runtime is exactly the same as the runtime in your Poser folder, only it's just sitting in a different location.
It functions exactly the same way.
And files are installed / added to them in exactly the same way.
And they have the same folders in them as the main runtime does. Well almost the same folders.  Scripts for example have to be installed into the main Poser runtime and won't work from an external runtime.
Here is a sample of an external runtime.  Simply download it and unzip it. You will have a folder called "Runtime_Sample"
www.divshare.com/download/8531562-1f6
Find a place on your hard drive that you want to have your external runtimes living. For me it's on my partitioned drive D.
Make a folder called "Poser Runtimes"
s263.photobucket.com/albums/ii124/Acadia_ca/
Then simply copy that sample runtime you unzipped into that "Poser Runtimes" folder and make as many copies of it as you want to.  Change "Runtime_Sample" to whatever name you want.  Here is what I named some of mine:
Then all you do is simply install your content into whichever runtime you feel it fits best into.
Once you have finished installing your content look in the Runtimes where you have Daz characters such as V3 or V4 etc.  Go into the Library folder and look for the !DAZ folder.  Make a COPY of that folder and place the COPY in exactly the same place in the main Poser Runtime.
Poser looks there first so by placing a copy of them in there, you are helping Poser out.  Don't delete the !DAZ folder from your other runtimes though. That defeats the purpose of having external runtimes, which is not only to allow Poser to work faster, organize your content better, but also to not lose your installed runtime content in the even of a crash because hopefully you have also saved your external runtimes to a couple other places for easy access in case of the need to reinstall.
Hope that helps.  If you have more questions, just ask.
Oh yeah, never install anything directly to your runtime. Always unzip / install to a folder on your desk top so you can see what is in side and what the folder structure is.
So far as organization inside the runtimes, continuity of naming goes a long long way.
Let's say for example that LaurieA gave me a beautiful clothing package for V4.  The package consisted of the following:
Dress
Shoes
Purse
Hair
Poses
When I get that file I will unzip it into a folder on my desk top in order to see what is inside.  Here is what I find
Dress inside a folder in the character folder aptly named "superstar dress"
Shoes inside a folder named "LaurieA" inside is another  folder named "V4" inside is another  folder named "props" inside are 2 more folders: 1  called "V4 Flats" and finally inside that folder are the shoe files, the other called "V4 Purse" with the purse file inside.
I find the hair  in the hair library, deep inside several folders as I did the props
And finally the poses for the figure are found in a folder in the Pose Library called "Gotta Have Fun" and another folder that simply said "dress textures"
Now if I were to install all of that into my runtime I wouldn't have a clue later on when I went to look for stuff to use from that one package, of what went with what!
Which is why it's important to open things onto your desktop and look through it and rename some of the folders that the vendor created.
The example of above is a very real nightmare that for some reason many vendors seem to do.  Another nightmare is using there real names as names for the folders instead of their vendor name.  That only adds to the confusion.
Here is how I would sort out the mess above while it was still on my desktop.
LaurieA - Superstar Dress
Yes, each folder in each libary is now called the same thing.  BUT I now have no doubt that when I do to use the superstar dress, that I will know what I'm looking at when I open up each library.
You can get even more organized.
For example under Poses, if you have found 5 new textures for that dress by 5 different artists, you can keep them all in one place. For example:
Artist 1 - (superstar dress) - sequins
Artist 2 - (superstar dress)  - dragon textures
Artist 3 - (superstar dress) - metalics
etc. etc. etc.
Just plunk those extra textures you found, as named above, inside the LaurieA - Superstar Dress  folder in the Pose Library.  Now when you want to use the superstar dress you have all of the textures at hand in one place.
tsquare ( ) posted Tue, 06 September 2011 at 1:54 AM
And then, there are always those that use "!!!!!!!mywonderproduct" for directory names and file names too!  :)
Teque
Belladzines ( ) posted Tue, 06 September 2011 at 3:26 AM
thankyou Acadia!!
