Fri, Jan 10, 3:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Convert Daz Character to Poser File?
tchamberlain2 ( ) posted Thu, 01 September 2011 at 2:05 PM · edited Mon, 23 December 2024 at 5:02 AM
Iv'e been realy trying to find out how to export a daz character to Poser 8. She's made from V4 . I wonder can it be done from daz or is there a plugin made to do it? Some one please help!
JunkoH ( ) posted Thu, 01 September 2011 at 2:31 PM
DAZ has a utility called Poser Format Exporter (PFE).
http://www.daz3d.com/i/3d-models/-/poser-format-exporter?item=8040
it exports figure settings to pz2, fc2, hd2 etc., and it works on morphs.
tchamberlain2 ( ) posted Thu, 01 September 2011 at 2:36 PM
Thank you so much.. So does this transfer the V4 Character or morphs to work on the V4 in Poser? I do have Poser Format Exporter. But I used it only to transfer over animations. But your saying I can transfer over more?
wdupre ( ) posted Thu, 01 September 2011 at 4:16 PM
V4 is a poser figure so no need to do any conversion or tranferring. it should open fine in poser, unless it was saved in a DS format, which would be strange. can you give more info on what the precise problem you are having is?
JunkoH ( ) posted Thu, 01 September 2011 at 4:36 PM
The product description linked above gives a capsule description on what it does.
Maybe you could tell what character it is and how you apply the morphs in the first place.  As wdupre mentions, it is rare that vendors supply V4 things in DS format only.
markschum ( ) posted Thu, 01 September 2011 at 4:51 PM
If you can save as a pz3 or pz2 or cr2 then Poser should be able to read the files.
