Thu, Dec 26, 6:17 AM CST
Subject: poser to bryce
garrr ( ) posted Thu, 23 August 2001 at 7:55 AM ยท edited Wed, 25 December 2024 at 6:30 PM
im having trouble importing the textures correctly from poser of michael into bryce 4..ie trans maps and bump maps...i think im doing it right in the picture editior in the tex editor in bryce but they keep on not rendering..help?
shadowcat ( ) posted Thu, 23 August 2001 at 2:15 PM
Attached Link: http://www.chesco.com/~cjcigas/tutorial/grouper/index.html
you may want to try using the grouper program, it prepares your export for bryce.
Poppi ( ) posted Thu, 23 August 2001 at 6:03 PM
Okay....One easy way is to put a copy of EVERYTHING you are exporting into a new folder and load into bryce from there. Bryce will be able to find your stuff. Also, it really helps to manually load all your transmaps and bump maps into a blank new bryce pic, before loading the .obj file. THat way, when or, if your eyebrows and lashes, etc., don't have the proper transparency...when you edit the materials you just have to click on the picture of your transmap, for the 2nd box of the three. Don't forget to hit the transparent dot in the same row as the diffuse dot. Set transparency to blend and you should be fine. No, Bryce 5 doesn't have a fix for this either.
