Fri, Feb 14, 1:17 PM CST
Subject: Render to disk hang up
Kurka ( ) posted Thu, 23 August 2001 at 2:03 PM · edited Fri, 14 February 2025 at 1:12 PM
Hi. I, and several other people, have had some problems with Vue 4 rendering to disk and hanging at 100% rendered. The problem, in my case, was a Win98 Second Edition glitch. -Win98 II has a problem with mapped drives shutting down and hanging programs. There a fix posted at the Microsoft updates pages. After runing the fix, I haven't had this problem anymore. - Hope this helps.
tradivoro ( ) posted Thu, 23 August 2001 at 2:19 PM
But I've shut down all that drive stuff and even with files that take 5 minutes to render to disk, I still get the same problem... So, I still think it's a vue problem....
smallspace ( ) posted Thu, 23 August 2001 at 2:45 PM
I'm running Windows ME and I get the problem as well. Last time I looked, there wasn't much in the way of significant ME updates. I'll have to take another look.
Kurka ( ) posted Thu, 23 August 2001 at 3:52 PM
There may, also, be a problem with the Batch.exe file. While I was fooling around trying to figure this out, I moved this file to a temp folder, and it had some effect. As far as shutting the drives down, I tried all that stuff without luck. It was only when I was checking the updates site that I saw this fix.-It worked for me.
Varian ( ) posted Thu, 23 August 2001 at 10:45 PM
Glad you found a fix, Fernando! I hope we'll be hearing of others getting help for it, too. :)
zoon ( ) posted Fri, 24 August 2001 at 1:25 PM
I've had this problem too. I always get the picture, its either on the disc or vue recovers it on the next re-start, but the program does crash at 100 percent. I din't get this in the beta testing, nor I think in release 4.0, so I suspect it is a vue problem. We'll see. Any one got the direct url of the win 98 II patch - I'm not mad about searching the unfathomable microsoft site.
Kurka ( ) posted Fri, 24 August 2001 at 3:29 PM
Attached Link: http://windowsupdate.microsoft.com
I forgot the name of the file,-sorry. But You can just click on start/windows update. The site will check for installed components. If you haven't downloaded it yet, it should show up there. Just look for a file that mentions "napped drives".
zoon ( ) posted Sun, 26 August 2001 at 3:51 AM
Attached Link: http://www.derby-vi-service.demon.co.uk/pictures.htm
I got the file, I think you meant 'mapped drives'! Thanks. Er... after two renders to disc, all is fine, but I'll keep checking. It may be a problem with windows, but Vue can get round it as it didn't occur during beta.
