You wouldn't have a render to show us, would you? Just offhand, sounds like back-facing polys... but I can't know without seeing something.
Please when asking for help, always say what version of Poser you have. I'm going to guess from "new copy of Poser" that it is P9 or PP2012.
Also you used the word "display" and not "render" or "preview". Display is ambiguous, so I'm guessing you meant preview.
In that case go into Render Settings, Preview tab, and disable "Remove backfacing polys".
Yes and Yes.
I'm new to Poser having Bought Poser Pro 2012. I'll post some images after I get back from the airport. It happens in the preview and render. Sometimes the blur faces one way or the other. some models... Like the P47 haved a prop sans spinner... you can duplicate and rotate 180. But basically in preview you see it from front (or back) but not from bit. Never seend it in Das Studio. but yeah I'm a noob and I am lost in the Materials room.
“So, roll me further B_t__h!”
You don't have to post pictures. I already know. Look at my post count.
Here I'll post pictures.
Here's an image I posted a couple years back with three props from behind, which were invisible at the time in preview. Poser didn't have an option to show them at that time.
http://www.renderosity.com/mod/gallery/full.php?member&image_id=1840092
Here's a quick Poser Render.... which stinks becsaue I don't know how to render yet and there is a light or something visible. It also messed up my tracers from Daz. Oy.......
http://www.renderosity.com/mod/gallery/index.php?image_id=2251174
Quote - I still use P7 and I cannot help you with render setting, but I wonder how to remove wireframe artifacts visible on wings. I have similar problem quite often I only what help is increasing minimum shading rate. Does anybody know how to fix it and do not loose render quality?
I don't know what you mean by wireframe artifacts.
I do know that Bazze materials load into Poser Pro plugged into the Gradient Bump, which is wrong. I move them to bump and they work much better. Perhaps that is the problem you are seeing? I don't have Poser 7 anymore.
Oh those. Your light's shadow bias is too low.
Or sometimes it is just from smoothing - try smoothing off to be sure.
Sometimes it is both.
I admit I'm kind of a dim bulb when it come to my new copy of Poser.... but can someone exlain to me why the Prop Driven Models Given away by Bazze display blurred props on only one side? They work fine in Daz Studio. I'm having troubles with the transition too Poser.
Thanks
