Fri, Jan 10, 7:13 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: PoserPro2012 won't load content
brewgirlca ( ) posted Mon, 26 September 2011 at 8:55 PM · edited Fri, 10 January 2025 at 5:27 PM
I bought a new multicore computer with windows 7 and 64 bit buss to run poserpro2012 to speed up my workflow. But now I find I cannot load any content files using Content Manager. The manager gives the message that the file is uploaded but when I go to the library it is empty. Doesn't matter if I load to download or poser2012.
Is there a poser setting I am missing or is it something in Windows 7 admin control that needs changing?
Also, and sorry for dumb question, but which version is the 64 bit bus - I assume it is the x86.
MacMyers ( ) posted Mon, 26 September 2011 at 9:09 PM
The x86 is the 32 bit version.
            “So, roll me further B_t__h!”
Believable3D ( ) posted Mon, 26 September 2011 at 10:45 PM
Probably too obvious, but may as well rule it out: Did you refresh the library?
______________
brewgirlca ( ) posted Mon, 26 September 2011 at 10:52 PM
Yes, I even rebbooted it.
PhilC ( ) posted Tue, 27 September 2011 at 2:18 AM
Which library did you install to?
Did you add that library to the library pallet?
See chapter 7 in the manual.
FightingWolf ( ) posted Tue, 27 September 2011 at 4:04 AM
I know that this probably isn't the solution but since I had similar things happen to me, I'll just bring it up.
Sometimes when I install content, I forget to change to the library that the content is actually in, so initially I think that the content didn't install.  For example, I'll install a figure and forget that I'm actually in the Pose Library looking for a figure.  The figure didn't show up because I was in the wrong library.
I have also had a similar case when installing hair.  I expect to find it in the hair library, but when there's nothing there when I go to the hair library.  After that I end up checking the figure library or the prop library in order to locate the hair.
It's a long shot solution for you but it happens.
estherau ( ) posted Tue, 27 September 2011 at 6:24 AM
the other thing might be to delete the library within poser then to locate it from within poser to add it as an external runtime.
MY ONLINE COMIC IS NOW LIVE
Marque ( ) posted Tue, 27 September 2011 at 8:11 AM
Are you installing it to the document folder by default or using your own library? Also I had an issue with 64 bit version where I had to update to flash 11 beta. No coffee yet so hope I got that version right.
DCArt ( ) posted Tue, 27 September 2011 at 11:29 AM
Are you talking about this Content Manager?
http://mattiasgustavsson.com/Blog/poser-content-manager/
If there is contact info for him in the readme or manual (or whatever is provided), I'd ask him if anything needs to change when upgrading to a Windows 7 computer, or what you need to do (if anything) to get it working with Poser Pro 2012.
Tucan-Tiki ( ) posted Tue, 27 September 2011 at 11:49 PM
same thing happened in poser 8, too bad they never changed that content browser set up to prevent this again.
