Tue, Nov 19, 2:50 PM CST
Subject: Cast Shadows With No Ground in PP2012..
RodS ( ) posted Wed, 05 October 2011 at 7:13 PM · edited Tue, 19 November 2024 at 2:22 AM
Haven't found an answer to this one yet, so here goes...
I'm trying to figure out how to make the default ground invisible without losing the cast shadows in Poser Pro 2012. I frequently composite Poser renders with photos (as layers in Photoshop). In Poser 8, I could make the ground invisible, and render the figures with the shadows intact. I can open a scene in PP2012 that was previously created with P8, and render with the ground invisible, yet retain the cast shadows.
I'll attach images to this post to show you what I mean.
The above image was created in P8, and rendered in PP2012. The girls were saved as a PNG file, and dropped into the gray background in Photoshop. Note the cast shadows.
"I reject your reality and substitute my own" - Adam Savage
RodS ( ) posted Wed, 05 October 2011 at 7:14 PM
This image was created in PP2012. With the ground visible, you get the cast shadows.
willyb53 ( ) posted Wed, 05 October 2011 at 7:15 PM
Did you try setting the ground plane to shadow catch only?
Bill
RodS ( ) posted Wed, 05 October 2011 at 7:16 PM
However, when I uncheck the "visible" checkbox for the default ground to make in invisible, it takes the cast shadows along with it!
Any ideas?
bagginsbill ( ) posted Wed, 05 October 2011 at 7:18 PM
willyb said it.
bagginsbill ( ) posted Wed, 05 October 2011 at 7:20 PM · edited Wed, 05 October 2011 at 7:23 PM
Note that this is not unique to the ground plane. You can make any shape of prop be a shadow catcher.
If you wanted a figure to cast a shadow shaped like it is falling on a wall and the ground, you could add a wall, also set to shadow catch only.
bagginsbill ( ) posted Wed, 05 October 2011 at 7:24 PM
And now against the other post background color.
RodS ( ) posted Wed, 05 October 2011 at 7:36 PM
Freakin' AWESOME!!!!
Dang - I just knew it was going to be something simple! Thanks so much, guys! Jeeze - I'm still such a noob...
"If you wanted a figure to cast a shadow shaped like it is falling on a wall and the ground, you could add a wall, also set to shadow catch only."
I love it!!! Thanks, BB - one of those things that's so obvious I've overlooked it ;-)
Thanks again!
bagginsbill ( ) posted Wed, 05 October 2011 at 7:45 PM
FightingWolf ( ) posted Wed, 05 October 2011 at 10:48 PM
Quote - However, when I uncheck the "visible" checkbox for the default ground to make in invisible, it takes the cast shadows along with it! Any ideas?
**Additional Solution#1: ** If you render on the grid that was the default in the Poser Pro 2010 then your shadows will render but not the ground.  It doesn't work with the default ground that Poser Pro 2012 uses.
**Additional Solution #2: ** You can select the ground and uncheck the  visible to camera setting. This will render everything but the ground.
You'll want to make the ground invisible when you want to render all the shadows except the shadows on the ground. This way you'll get the depth on the image without having the shadows on the ground.
