Fri, Nov 22, 4:47 PM CST
Subject: Was wondering?! Can you Import a Background into Bryce?
FutureFantasyDesign ( ) posted Tue, 04 October 2011 at 3:00 AM · edited Tue, 19 November 2024 at 7:17 PM
I want to import my own background/backdrop into bryce and then build over it. Is this possible? If it is could someone please explain the proceedure?
ThanX!
Ariana
Is there water in your future or is it being shipped away to be resold to you?
Water, the ultimate weapon...
www.futurefantasydesign.com
TheBryster ( ) posted Tue, 04 October 2011 at 9:10 AM
Forum Moderator Online Now!
You could create a cube, stretch it to the width of the screen and apply a .jpg to it as your background.
erosiaart ( ) posted Tue, 04 October 2011 at 9:38 AM
wouldn't a flat plane do too?
FutureFantasyDesign ( ) posted Tue, 04 October 2011 at 11:05 AM
Not sure. I can try. I have never applied a texture that wasn't already created, like terrains and such. Do I import it in the materials section? Do I have to create it as a alpha like the rose I did?
Would someone mind telling me the import process?
I am installing PP2012 at this moment, but I can make time to do this tomorrow.
Thank you all...
HugZ!
Ariana
johnyf ( ) posted Tue, 04 October 2011 at 11:51 AM · edited Tue, 04 October 2011 at 11:52 AM
Click on "Leo" to import your photo background. By using Leo your image will be correctly proportioned.
Then just position to suit in the scene.
FutureFantasyDesign ( ) posted Tue, 04 October 2011 at 4:38 PM
Thank you JohnnyF!!!
I will give that a go as soon as I get my RT set up in PP2012!
HugZ!
Ariana
mtnmen ( ) posted Fri, 14 October 2011 at 12:29 PM
When I import a picture that I want applied to an object, a cube let's say... I always have the picture applied to "top of object" and then maneuver the objects top into the workspace as I want it to be viewed... That way seemed easier to me with little manipulation, than applying the picture to a side or any of the other possible ways of applying the picture.  Once in your scene... you  might want to turn off "receiving shadows" so objects in the scene don't affect the "background" on  the cube..
Steve
Analog-X64 ( ) posted Fri, 14 October 2011 at 6:43 PM
This topic reminds me of something called Simply 3D from Micrografx which I think Corel bought back in the day.  It had a feature where you could simply load an image and it would become the backdrop and would reflect into objects.
ThunderStone ( ) posted Sat, 15 October 2011 at 10:58 AM
Quote - This topic reminds me of something called Simply 3D from Micrografx which I think Corel bought back in the day.  It had a feature where you could simply load an image and it would become the backdrop and would reflect into objects.
I still have that program on my HD and from time to time when I need to use an object that I can't find anywhere, I will export it from there as VRML and then into 3D Max to export it out as either 3DS or OBJ... Crude but effective! Really which I could use it in Win 7.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Analog-X64 ( ) posted Sun, 16 October 2011 at 8:30 AM
Quote - I still have that program on my HD and from time to time when I need to use an object that I can't find anywhere, I will export it from there as VRML and then into 3D Max to export it out as either 3DS or OBJ... Crude but effective! Really which I could use it in Win 7.
Simply 3D was a joy to use and it made me realise that it would be possible to work with 3D on my computer compared to 3d Max (DOS Version)
My first render was a brick room I built and in the corner was 3 types of spheres, glass, metal and plastic, it looked amazing at that time.
I just realised that my first render was not a Sphere over Water :)
ThunderStone ( ) posted Sun, 16 October 2011 at 8:59 AM
No... but 3 spheres in a corner over dried water, eh???? 😉
