Fri, Nov 15, 7:01 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Rename a figure from Python
markok13 ( ) posted Thu, 20 October 2011 at 1:52 PM · edited Fri, 15 November 2024 at 6:51 AM
Is there a way for a Python script to change the name of a Poser Figure?
I assumed there would be a SetName() method, just like there is for Actors, but I can't find anything in the Methods Manual, or in a dir() of a Figure object.
markschum ( ) posted Thu, 20 October 2011 at 5:34 PM
The name in the cr2 is towards the bottom where all the addchild statements are.
I dont see  a python method for changing the name.
You could do a script to change the name in the cr2  and then load it using loadlibraryfigure.
Dimension3D ( ) posted Mon, 14 November 2011 at 12:33 PM
SetName() for figures was introduced in PoserPython for Poser 9.
Dimension 3D - Poser Tools, Poser Props and Morphs, Cinema 4D Plugins, and more
Renderosity Store / D3D Web Site
