Tue, Jan 21, 1:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: environment dome with IDL enabled.
3anson ( ) posted Sun, 30 October 2011 at 6:34 AM · edited Tue, 21 January 2025 at 1:43 PM
ok, being a total newbie with PP2012, if i make the dome invisible to camera and raytracing but leave the light emitter box ticked, does Firefly still use the dome and its image in IDL calculation?
ie i need the light effect, but want to overlay the render onto a BG of my choosing.
millighost ( ) posted Sun, 30 October 2011 at 7:49 AM
Quote - ok, being a total newbie with PP2012, if i make the dome invisible to camera and raytracing but leave the light emitter box ticked, does Firefly still use the dome and its image in IDL calculation?
Sounds like you want just a plain old image based light, for that you do not need to use a skydome or similar; it does use a different map-type, though.
As for the IDL/2012, i do not know, but why not try it out? Just disable all other lights, leaving only the skydome on and render it, if you get anything lit, it works :-)
wimvdb ( ) posted Sun, 30 October 2011 at 7:53 AM
You need to have raytracing enabled for IDL calculation. So set invisible to camera and have the Emit light box ticked. As a texture you can use a texture or material for the environment dome and you can make it grayscale to eliminate color influence
3anson ( ) posted Sun, 30 October 2011 at 8:01 AM
thankyou!!
hborre ( ) posted Sun, 30 October 2011 at 11:31 AM
Online Now!
I don't understand why you should make a skydome invisible to the camera when a skydome should be large enough to include most camera settings.  Even BB's envsphere is large enough to use for aerial scenes.
3anson ( ) posted Sun, 30 October 2011 at 11:35 AM
Quote - I don't understand why you should make a skydome invisible to the camera when a skydome should be large enough to include most camera settings.  Even BB's envsphere is large enough to use for aerial scenes.
because i have few image maps that suit the skydomes, so i want to use the BG images i do have, and layer the render over .
RobynsVeil ( ) posted Sun, 30 October 2011 at 4:34 PM
Not sure if this would work for you, but I found that to get reasonable image resolution on a sky dome, you have to go to focal-spot of 35 or something, which for figures falls a bit short of complimentary.
So, I use a panorama (curved) plane displaying the image I want to use as backdrop, and a skydome for lighting. Not ideal but it works.
Metaphor of Chooks
3anson ( ) posted Sun, 30 October 2011 at 5:00 PM
lol! i have trouble with domes anyway, as i tend to use a focal length of 250 on my render camera
