Wed, Feb 19, 2:41 AM CST
Forum Moderators: RedPhantom
Subject: Minimize Poser Pro 2012 during render?
Cage ( ) posted Mon, 07 November 2011 at 8:53 PM · edited Wed, 19 February 2025 at 2:39 AM
Is there any way to minimize Poser Pro 64 bit during a render, or while a Python script is running?  I thought this was possible on 32 bit Windows using the "runbelownormal" trick that Bagginsbill revealed some time back, but I can't find any such trick for Windows 7 64 bit.
willyb53 ( ) posted Mon, 07 November 2011 at 9:09 PM
Try render to background
Bill
Cage ( ) posted Mon, 07 November 2011 at 9:17 PM
Ooh.  I'd never thought to try that feature.  :laugh:  Thank you.
Medzinatar ( ) posted Mon, 07 November 2011 at 9:51 PM
I usually just use the Windows "show desktop" button.
Cage ( ) posted Mon, 07 November 2011 at 9:55 PM
Quote - I usually just use the Windows "show desktop" button.
There's a "show desktop" button?  😕  Where is it?
Medzinatar ( ) posted Mon, 07 November 2011 at 11:00 PM
Quote - > Quote - I usually just use the Windows "show desktop" button.
It is an unlabled small rectangle at the end of taskbar on right. If you mouse over it the title will appear momentarily.
Cage ( ) posted Mon, 07 November 2011 at 11:09 PM
Quote - It is an unlabled small rectangle at the end of taskbar on right. If you mouse over it the title will appear momentarily.
Wow!  That's one of those things I've seen over and over again, but never actually noticed.  I guess I thought it was some decorative element, or something.  :lol:
Thank you.  :laugh:
bantha ( ) posted Mon, 07 November 2011 at 11:35 PM
There is also a keyboard shortcut for this - [Windows Key]-[D].
-"Amazing Grace" Hopper
Miss Nancy ( ) posted Mon, 07 November 2011 at 11:45 PM
in OS X, clik yellow (-) button on upper left.
imax24 ( ) posted Tue, 08 November 2011 at 1:17 AM
Poser 8 and Pro 2010 did not like to be left to render while one did other tasks on the computer. In fact it didn't even need to be rendering. It was a very jelaous mistress and would generally (but not always) crash if you switched away from it. This is the Mac version. Poser Pro 2012 is much better in the regard. I think they cleaned up some memory problems in this version.
jaguarmma ( ) posted Wed, 09 November 2011 at 10:14 PM
I noticed my renders crashing when I even thought about minimizing the application or clicking the show desktop button.
I have the 2012 version and recently its been acting really strange when it comes to render times =(
Is there a way to minimize the risk of it crashing while rendering?
or
Is there a faster method to boost up the rendering engine itself?
I posted a thread earlier about this but no replies
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2838996
Hopefully someone really awesome like Bagginsbill or Tempesta3d can shed some light =)
jaguarmma ( ) posted Thu, 10 November 2011 at 12:15 AM
Is there an advanced render settings plugin?
or
A way to choose rendering in Quicktime or Divx yet?
bantha ( ) posted Thu, 10 November 2011 at 1:04 AM
Do you want to use a differend rendering engine or do you want to have more control to Poser's Firefly renderer?
If you want the later, you will find advanced options in the menu:
[Scripts][Partners][Dimension 3D][Render Firefly]
If you want to use a different render engine for movies I would suggest you take a look at Vue, which can import Poser szenes and even keep the Poser materials when needed. No idea how stable this is when rendering movies, you might want to ask for it in the Vue forum. You will find Vue here
You can render directly into Divx if you have the codec installed. But usually it's better to render in single images and create the movie from them later. This way, you won't have to redo eveything if something goes wrong.
jaguarmma ( ) posted Thu, 10 November 2011 at 2:46 AM
Quote - Do you want to use a differend rendering engine or do you want to have more control to Poser's Firefly renderer?
thanks I'll try rendering my scenes using the advanced setting =)
jaguarmma ( ) posted Thu, 10 November 2011 at 2:53 AM
under the advanced settings to render a series of images do I put
1 - 286  in the frames section?
bantha ( ) posted Fri, 11 November 2011 at 12:04 PM
Yes, that's right.
jaguarmma ( ) posted Fri, 11 November 2011 at 1:19 PM · edited Fri, 11 November 2011 at 1:19 PM
I tried rendering the movie under the make movie section and it crashed on the 5th frame sometime last night.
It seemed the advanced render section is the only way I can render a frame.
Hopefully it will work on multiple frames too =)
jaguarmma ( ) posted Sat, 12 November 2011 at 1:23 AM
it worked but noticed a prop going through a character on the 40th frame. Had to stop it so I can adjust the mistake.
jaguarmma ( ) posted Sat, 12 November 2011 at 2:15 AM
Thanks bantha for giving me less stress lol
