Sat, Feb 1, 4:57 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Assign a drive letter to a folder
Tiny ( ) posted Thu, 10 November 2011 at 6:13 AM · edited Mon, 20 January 2025 at 3:00 PM
This is more a general Python question since I'm after a standalone solution.
I'm looking to make a two click solution for assining a folder a drive letter.
Click to start the app which shows available drive letters.
Click to choose a letter. App closes. Done
To delete the drive letter chosen earlier there should only be one click.
Is this doable?
bagginsbill ( ) posted Thu, 10 November 2011 at 7:24 AM
Yes it is. Did you want more info than the confirmation it is possible?
bagginsbill ( ) posted Thu, 10 November 2011 at 7:27 AM · edited Thu, 10 November 2011 at 7:27 AM
I can't recall if you're a coder. If you are just looking for kick-start information:
http://www.google.com/search?q=python+wnetaddconnection2
Tiny ( ) posted Thu, 10 November 2011 at 7:44 AM
Thanks BB. Also for the laugh from your first post. Needed that. :)
Am not a Python coder but can understand a bit of what is going on.
Thanks for the search terms. Had no idea what it may be called. I will go on from there.
