Wed, Feb 19, 2:09 AM CST
Forum Moderators: RedPhantom
Subject: Hidden Gen4 Morphs in Genesis Visibility Script
colorcurvature ( ) posted Wed, 16 November 2011 at 1:13 PM · edited Thu, 16 January 2025 at 6:54 AM
Here is the script to unlock the hidden  GEN4 morph targets in Genesis, if you didnt buy the M4/V4 Morph package for genesis they might still be useful for one thing or the other.
Genesis will not bend with these shapes, however, unless you adopt the joints.
http://cgscripts.colorcurvature.com/Unlock_Genesis.py.txt
Must be saved as .py and executed with File->Run Python script
jonnybode ( ) posted Wed, 16 November 2011 at 10:49 PM
Thank you, this can be useful!
colorcurvature ( ) posted Thu, 17 November 2011 at 8:21 AM
I removed the link. There is actually a far better free script for showing and hiding dials by Dimension3d.
http://www.renderosity.com/mod/freestuff/details.php?item_id=37119
Bejaymac ( ) posted Thu, 17 November 2011 at 7:05 PM
ROFL those 'morphs' are for DS4's autofit plugin, those are the base shapes it uses when it converts a mesh, same idea as X-Dresser except the 'templates' are supplied with & 'built into' Genesis.
PS The females all have V4's shape & the males have M4's, and just being deltas they are also pretty useless for anything else.
jonnybode ( ) posted Thu, 17 November 2011 at 11:20 PM
How can they be useless?
We get a free low res weightmapped figure, and "hidden" inside it are the shapes of M4 and V4.
I can think of many ways to use these characters, I exported my copy from Daz Studio 4 with a V4 UV-map and i works pretty well in Posers clothroom with some dynamic clothing.
Bejaymac ( ) posted Fri, 18 November 2011 at 7:17 AM
The WM and rig is for the base shape of Genesis, it doesn't adapt to fit those morphs like it does with the other morphs, this means they don't bend as good. But hey, if your that desperate to use a halfassed, badly working piece of crap in P9/PP12 then go ahead, if it was me I'd sooner wait for Mike to finish his WM V4.
jonnybode ( ) posted Fri, 18 November 2011 at 10:05 AM
quote
end quote
Thank you, I was waiting for your approval!
WandW ( ) posted Fri, 18 November 2011 at 11:14 AM
Quote - The WM and rig is for the base shape of Genesis, it doesn't adapt to fit those morphs like it does with the other morphs, this means they don't bend as good...
I presume CC's PML/Joint Recenter script would fix that.  One could then drop the resulting rig into V4 or M4 clothing in the Setup Room...
pjz99 ( ) posted Fri, 18 November 2011 at 3:37 PM
Quote - The WM and rig is for the base shape of Genesis, it doesn't adapt to fit those morphs like it does with the other morphs, this means they don't bend as good. But hey, if your that desperate to use a halfassed, badly working piece of crap in P9/PP12 then go ahead, if it was me I'd sooner wait for Mike to finish his WM V4.
So what if someone else uses a piece of software in a certain way, how in the world does that provoke rudeness from you?
My Freebies
