Sun, Nov 24, 12:55 PM CST
Subject: Teeth get left behind ...
A_Sunbeam ( ) posted Mon, 19 December 2011 at 7:34 AM · edited Sun, 24 November 2024 at 12:52 PM
Why is it that V4's teeth sometimes get left behind when her head or body is moved?
SamTherapy ( ) posted Mon, 19 December 2011 at 8:25 AM
Maybe Mike's been slapping her around.  ;)
Sorry, I got nothin'.
richardson ( ) posted Mon, 19 December 2011 at 9:39 AM
It used to be a need for a video driver update.
hornet3d ( ) posted Mon, 19 December 2011 at 11:41 AM
I had this problem a year ago or more but it only happened when I had the 'point at' set for the eyes.
Plutom ( ) posted Mon, 19 December 2011 at 11:48 AM · edited Mon, 19 December 2011 at 11:50 AM
You should have the Update Victoria 4 base on your desktop, have you clicked on that? Or check and see if it is parented correctly under the face?
Jan
A_Sunbeam ( ) posted Mon, 19 December 2011 at 12:35 PM
So (hornet3d) it could be the "point at" - which I use for the eyes very very often; and (Plutom) I'll check on the parenting.
FrankT ( ) posted Mon, 19 December 2011 at 1:28 PM
Online Now!
Another vote for point at.  I've had the same problem before
My Freebies
Buy stuff on RedBubble
Acadia ( ) posted Mon, 19 December 2011 at 2:00 PM
It's computer lag related to your graphic card not being able to keep up.  Right click in your working window and see what you have active IE: SreeD or OpenGL.  Try changing to SreeD.
I have that problem with my current graphic card (which is onboard vs stand alone), and it can't run OpenGL, so in PoserPro2010, Vicky's teeth are always floating out front or poking through her mouth.
FrankT ( ) posted Mon, 19 December 2011 at 3:23 PM
Online Now!
I get the same effect with an nVidia GT240 with 1GB Ram so it's not that
My Freebies
Acadia ( ) posted Mon, 19 December 2011 at 3:51 PM
Quote - I get the same effect with an nVidia GT240 with 1GB Ram so it's not that
Did you try right clicking in the working window and picking another viewing option than what you are currently runnin? IE: ScreeD instead of OpenGL or vice versa?  You can't say it doesn't work until you have at least tried :)
FrankT ( ) posted Mon, 19 December 2011 at 5:20 PM
Online Now!
yup - tried both and it didn't help.  Never happens to me if I don't use point at though
My Freebies
