Sat, Jan 25, 3:32 PM CST
Subject: Working on JCM
eltoro3D ( ) posted Sat, 17 December 2011 at 9:53 AM · edited Sat, 25 January 2025 at 3:31 PM
but i think i don´t get it right ..
I have my modell done ... and as I said I just working on the JCM .. I´ve just bought morph clothes from Dimension 3D .. Now when  Michael bends his arm the JCM -Morph should just work say only lcollar + l shoulder + lForeArm but I ´m not sure Im doing something wrong ..
Is there any Tutorial out there how I can setup JCM inside newClothes ??
PhilC ( ) posted Sat, 17 December 2011 at 10:16 AM
Are the morphs of such a significance that they would be evident when worn with clothing?
eltoro3D ( ) posted Sat, 17 December 2011 at 10:19 AM
Yes because through the bends the coat looks very ugyl so Ihave to fixed while bending the joints
lesbentley ( ) posted Sat, 17 December 2011 at 11:57 AM
You mention a coat. Is this a problem with a normal figure, or with a conforming figure? And what exactly is the problem? You don't say what is wrong in your post, just that "i don´t get it right". You are not giving us much to go on here.
If it's a conformer, the JCM needs to be slaved to the joint rotations of the character figure, not those of the conformer itself.
RobynsVeil ( ) posted Sat, 17 December 2011 at 7:12 PM · edited Sat, 17 December 2011 at 7:13 PM
Quote - but i think i don´t get it right ..
This, perhaps?
Metaphor of Chooks
steveshanks ( ) posted Sun, 18 December 2011 at 1:36 AM
When you went to the "Transfer" tab did you click "Enable cross talk", Steve
eltoro3D ( ) posted Mon, 19 December 2011 at 11:23 PM
Allright then thanks to @all for helping me out.. I know I have to practice this :)
As I said I´m not really satisfied with the bending and want to adjust the bending inside zbrush and make then then morph .. The moprh works and it looks fine .. but how do i make the JCM ? I knew something like inside yrotate i have to put someting... But I want to know can I do this by Hand or with a Tool like Morph Clothes or Poser Editor .. Also I would like to ad Some Folds Morpjs while bending ..
Thanks a lot for any Tips learning this ..:)
ElorOnceDark ( ) posted Thu, 22 December 2011 at 9:04 PM · edited Thu, 22 December 2011 at 9:05 PM
There are a few ways of doing this.  If you are a Daz Studio user, the Morph Loader Pro tool makes this easy.  If you don't use DS, you can do it manually in Poser.  Just create your morph in you modelling ap, then load the morph into your clothes in Poser.  Use a text editor on your clothing cr2 to add in the code for making the JCm automatic.  Here is an example of the code for M4's collar bend JCM from my Immortal Ronin shirt.  I only needed the JCm to activate when the collar was bent up, so that's why the minimum value is set at zero.
