Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Quote - Updated to SR1, now there's nothing in the Library Pallette. No runtimes, no buttons or icons that can be clicked, nothing at all. Closed the pallette and reopened it, didn't help. I was only using the internal library before the update.
Win or Mac. If it altered the library settings, then it should have made a backup of you library prefs. DL'ing my self and doing a full back up before I install, otherwise I could answer better. Look for a file LibraryPrefs.xml. This is the file that points at your runtimes. You can edit with a text editor or possibly replace with a back up. Add a runtime first to see if that solves the problem. then look at the file and check the paths.
Gary
Internal is not AIR so updating that is unhelpful. Internal is Flash. But... many things can be the problem. If there are no buttons at all, that is odd.
Be aware that if you have firewalls or UAC or any other clever stufff protecting you, Poser SR means your system thinks this is new software and will not apply what you told it before. It sometimes even thinks your Poser executable is now a virus becuase it is not the same as it was yesterday. Hahahahaah. People should band together and literally hunt down and kill Virus authors. They have no redeeming qualities and they steal time from literally billions of people. They should die.
PS: I have been enjoying some wine.
Recovering from a major remote drive melt down so fell out of the beta testing loop...but
in scanning the PP2012 SR1 readme :biggrin: About time
Figures with IK load into scene obeying IK settings as saved to library
Gary
Thanks for the heads up!
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Quote - > Quote - Win or Mac. If it altered the library settings, then it should have made a backup of you library prefs. DL'ing my self and doing a full back up before I install, otherwise I could answer better. Look for a file LibraryPrefs.xml. This is the file that points at your runtimes. You can edit with a text editor or possibly replace with a back up. Add a runtime first to see if that solves the problem. then look at the file and check the paths.
This is the Mac version of PP2012. LibraryPrefs.xml had the correct paths, but I replaced it with a pre-SR1 backup anyway. Didn't help. Besides, the problem isn't just no runtimes in the Library, there aren't even any buttons to click to add a runtime, or tabs, or options bar at the bottom, or anything. The whole Library UI is missing. I had the latest Flash prior to SR1, as well.
Hi!
Does anybody know if the SR is available at Content Paradise? Ive looked but cant find any.
I would download it from Smith Micro but ive had trouble getting every released SR from them as both
https://store.smithmicro.com:4433/signin.aspx
and
https://store.smithmicro.com:4433/signin.aspx?ReturnUrl=cart.aspx
times out for me and refuses to load (happens at home and at work as well).
I usualy end up writing Smith Micro support but would be happy not to go down that route again.
Why don't you try the link in the first post in this thread?
http://poser.smithmicro.com/updates.html
It is a direct link to the download page
Hi!
quote/
/end qoute
I do go by that link, but to download the SR you have to continue to the links in my post.
Quote - > Quote - > Quote - Win or Mac. If it altered the library settings, then it should have made a backup of you library prefs. DL'ing my self and doing a full back up before I install, otherwise I could answer better. Look for a file LibraryPrefs.xml. This is the file that points at your runtimes. You can edit with a text editor or possibly replace with a back up. Add a runtime first to see if that solves the problem. then look at the file and check the paths.
Some other problem. Just updated my Mac 10.6.8 same Poser Pro 2012, no issues with the lib
Gary
imax24, was your update applied to disk-installed version? which flash version have you?
in response to imax24's post which occurs 2 posts after this one, would suggest installing apps in apps folder, even if apps installers seem to violate obsolete (>=10.6) OS X rule against installing content in apps folder.
p.s. one should not kill bill's "Virus authors" - rather one should use them, as we saw in a recent Iranian incident.
Is the service release: 9.0.1.18621... ?
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
grichter, did you notice that the Mac installer skips right past the Destination step and doesn't let you choose where to install? It automatically installs to the Applications folder even if PP2012 is installed somewhere else.
Thus there is a partial install (with a new PP2012 app and a few new runtime files) in Applications and my original full install, not iupdated, in a different place. I manually copied the new stuff into the original installation folder, replacing where necessary. I suspect somehow in there I lost the library.
I will probably have to move my original install to where the updater expects it to be. Because the updater doesn't seem to know there IS no Poser where it is installing the new files. It's creating a new Poser 2012 folder and a new, very incomplete runtime.
Quote - grichter, did you notice that the Mac installer skips right past the Destination step and doesn't let you choose where to install? It automatically installs to the Applications folder even if PP2012 is installed somewhere else.
Since I have it in my apps folder and content in my share folder all the PP2012 default locations, I didn't pay attention of where it was going. Just let it run.
Gary
Quote - I didn't have any problems with the library and preferences once I copied my backed up ones over. However, in preview I no longer see shadows, which is a pain.
It sounds like the update reset your Preview settings. You should be able to change it back to use hardware shading and show shadows in Preview.
Personally I only use shadows in Preview to check the lighting, then turn them off again once I'm satisfied. It bogs down camera and dial performance too much for my taste to leave it on all the time.
Quote - > Quote - grichter, did you notice that the Mac installer skips right past the Destination step and doesn't let you choose where to install? It automatically installs to the Applications folder even if PP2012 is installed somewhere else.
Well, moving my original installation to Applications and then running the update did the trick. Apparently, even though the original installation lets you choose where to install, the Mac updater doesn't. It puts its new files in only one location (Apps) whether Poser exists there or not. You have to move your original install where the updater wants it to be, and you have to do it BEFORE running SR1. There is no mention of this in the Read Me, of course.
Attached Link: http://www.contentparadise.com/productDetails.aspx?id=20260
> Quote - Does anybody know if the SR is available at Content Paradise? Ive looked but cant find any.It's easy to generate the URL for the CP item page from the SM URL, link attached.
it sounds like an awful lot of trouble to installe the SR
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Quote - Ok... I screwed it up... Library on Win PC is gone. I didn't Back up and I don't seem to have a prefs.xml file. Does I gotta reload all of the content libraries?
In my case, on a Mac, I lost the Library because the installer expects to find Poser in one place and one place only. I had moved Poser after initial installation, and the updater isn't smart enough to deal with that. I don't know if it's the same deal for the PC version, or if that's your problem at all. If it is, you need to move or re-install Poser to where the updater expects it to be, then install SR1.
no MacMyers
I never do that. there are python scripts for this.
Sorry I can't point you in the direction of the one I have that will load them all at once from semidieu, but there is one in poser for loading all the preferences from your previous poser version. so go to scripts at the top of your poser and look around. You might be surprised what other little helpful goodies are there.
Love esther
I aim to update it about once a month. Oh, and it's free!
Quote - > Quote - I didn't have any problems with the library and preferences once I copied my backed up ones over. However, in preview I no longer see shadows, which is a pain.
That didn't seem to help.
Attached Link: http://www.runtimedna.com/Semidieu/
without my python scripts my poser life would be very very hard.Love esther
PS did you get your runtimes reinstalled. If not get in touch and PM me.
The SR1 does not change settings.
If your current default was set to 1?
Set it back to 2.2 and save under General preferences as your default scene.
I have a very personal default scene, and its the first thing I do after every update.
Load my preferred scene and save it as my default under General preferences.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
I must be doing something wrong. The SR installed without issue. No settings were changed. My defaults remained as they were. No runtimes disappeared. The only changes to my default setup is that the D3D render script had SSS ticked as a default. Not a bad thing. My Queue Manager did request the serial number to be enterd again but I don't see that as a problem either. Win 7 64 with heavy duty UAC mods applied at all times. I did not update the 32 bit installation as I do not have it installed.
pdg
Quote - I must be doing something wrong. The SR installed without issue. No settings were changed. My defaults remained as they were. No runtimes disappeared.
Did you tick the "keep settings" option?
I didn't. I flew through the screens so fast I didn't read carefully.
If you do choose the keeps settings option, it does keep all your settings and libraries. (I know, because I also updated a copy of Poser 9. I went slower with that one, changed the default option to keep settings, and it did keep all my settings and runtimes.)
I still think the default should be keep settings, rather than revert to factory, but I should probably read more carefully before clicking "next." One of these days I'm going to end up being Bill Gates towelboy because I clicked "I agree" without reading it first. ;-)
The queston to remove, backup, or keep the prefrences is normally asked during the SR1 install.
If any change happened during the SR1 install, it is here that you had the choice to do so or not.
Where the backup files go, depends on your OS and UAC settings.
The default setting for gamma correction in the render settings still is 2.2 (PoserPro2012) Poser9 does not have gama correction.
SSS is defaulted to ON in the normal render settings also.
Happy Posering to ya all.
Tony
Dev
"Do not drive
I know Poser 9 doesn't have GC. I have copies of both 9 and 2012. And, Poser 2012 set itself to 1 when I applied the update. I never changed the original setting, and anyway, as I said, all settings reverted to factory defaults because of the option I (didn't) choose. And GC is now 1.00.
No big deal to change it back. I'm just curious about why the default has changed.
Since updating with SR1 there has been a significant lag when switching cameras and when typing text in PP2012 (Mac). First there is a delay of a coouple seconds when nothing happens, then there is a further delay of 3-5 seconds while The Beachball of Death spins. This did not happen before SR1.
An odd thing with the typing -- this lag thing happens even when typing in a Save dialog as well as typing in parameter values or naming something to save to the library.
Anyone else, MAc or PC, see this?
A nice fix that is not documented: I no longer must move my cursor over the Preview window before any action in the Library takes effect. This was a problem in the original PP2010 and was fixed in one of the SRs, then appeared again in the original PP2012.
Gary
