Fri, Dec 27, 1:22 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Help-Camera panning question
datastorm ( ) posted Sun, 26 August 2001 at 2:04 PM · edited Thu, 26 December 2024 at 11:34 AM
I have a scene where a jet is doing a fly-by. I want the camera to point at the jet and track its movement. I used the point at command in the properites tray/modifiers window. But what is happening, is that camera is moving with the jet. What I want is for the camera to stay still and just turn or (I guess you call this panning) pan with the jet as it goes by. Is there a solution? Thank you very much
keithw ( ) posted Mon, 27 August 2001 at 8:21 AM
You can use key frames to do this. Set a key frame with the camera pointing at the jet at its start position and another with the camera pointing at the jet' end position. Keith
litst ( ) posted Mon, 27 August 2001 at 1:23 PM
Datastorm, are you sure you're not using the "track" behaviour instead of "point at" behaviour ?
datastorm ( ) posted Mon, 27 August 2001 at 3:21 PM
Is that what I'm suspose to use . . .the "point at" behavior?
litst ( ) posted Mon, 27 August 2001 at 4:06 PM
Yes :) The "point at" behaviour in the z axis . The "track" behaviour makes an object follow another one, in position or orientation, so that's definitively not what you need ;)
AzChip ( ) posted Sat, 01 September 2001 at 10:56 PM
Yep -- "Point at" is panning, "Track" is, well, in movie-making terms, tracking with an object -- or moving the camera along with the object. Hope you have your answer!
