Fri, Jan 24, 4:59 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Drop to Floor Problems
grichter ( ) posted Mon, 09 January 2012 at 3:39 PM · edited Thu, 23 January 2025 at 8:51 PM
When I run the following pz2 which calls a script since the upgrade to PP2012 SR1, V4 which is the only character that seems to have the problem (V3. M3, M4 all work as expected) goes negative y -10320000.000000. Same occours if I run just the drop to floor script from the scripts menu.
Anybody got a clue why this is haywire all of a sudden?
Thanks in advance for any assitance.
version
    number 6
actor BODY
    channels
        valueParm SCLS4Short
            keys
                k 0 0.400
runPythonScript ":Runtime:Python:poserScripts:ScriptsMenu:Utility:dropFigToFloor.py"
which calls this script
scene = poser.Scene()
actor = scene.CurrentActor()
actor.DropToFloor()
Gary
semidieu ( ) posted Mon, 09 January 2012 at 4:09 PM
And does it occur the same if you drop to floor using the Figure menu from Poser ?
And what is the actor selected before running the script ?
grichter ( ) posted Mon, 09 January 2012 at 10:03 PM · edited Mon, 09 January 2012 at 10:05 PM
Yes the actor is selected and the figure menu drop to floor works as expected, But the value gets stuck at-10320000.000000 if you do it after running the script. You get the character back in the scene instead of 10,320,000 poser units below the poser ground plane. But the value shows -10320000
I have a bunch of scripts I wrote to create charatcers for various scenes, where I either use the SP4 proprotions on V4 of via proprogating scalling to change their physical height, etc of other characters and load texture maps, and morphs, etc.  They all include a drop to floor at the end of the character creation script. Agian only the V4 characters have the problem.
Gary
markschum ( ) posted Mon, 09 January 2012 at 11:55 PM
what display units are you using ?
grichter ( ) posted Tue, 10 January 2012 at 6:16 AM
Poser Units
Gary
EnglishBob ( ) posted Sat, 14 January 2012 at 5:16 AM
Sorry, I have nothing useful to contribute - but that offset value is interesting, given that 1 PNU = 103.2 inches. I can't figure what the connection is, if any. Just a bug in actor.DropToFloor(), most likely.
grichter ( ) posted Sun, 15 January 2012 at 10:16 PM
I am beginning to believe it is a scaling issue. All the V4 characters that have problems have the SP4 proportions morph injected, and set from .1 to .5 in the various cr2's I load. Don't hold me to that, still messing around.
Gary
markschum ( ) posted Sun, 15 January 2012 at 10:37 PM
I wonder if changing to box tracking would reveal anything interesting ?
grichter ( ) posted Sun, 15 January 2012 at 10:49 PM
Quote - I wonder if changing to box tracking would reveal anything interesting ?
No difference
Gary
lesbentley ( ) posted Sun, 18 March 2012 at 2:29 AM · edited Sun, 18 March 2012 at 2:30 AM
Check yTran of the Body, before and after running DTF, does it change?
Also, if there are any body handles involved, that could be a cause.
Another suspect could be the V4 native magnets. This is just a wilde guess, but it's one thing that V4 has, and most other figures don't. Yet another suspect might be that the hidden bodyMoprphs actor is involved in some way.
