Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Check to see if the product has utility poses that will pose the foot to fit the shoe.
If there isn't. load the shoes. Turn off IK for the figure's legs. Bend the feet and toes to the aproximate shape of the shoe. Move the shoes into place and adjust the foot position.
If the shoe is parented, parent it to the foot. If it conforms, conform it.
If you still have the same issue, adjust the shoe so that the heel and sole are on the ground. Some conforming shoes are better parented to the feet rather than conforming.
This type of shoe doesn't lend itself well to hiding the feet and toes.
Give us some more detail and you will probably get better answers, but here is something to try. Go to the shoes property window and check “include scales when conforming” and/or “include morphs when conforming”. Play with these and see if it helps.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
Also, are the shoes for that particular model? They need to be correct for the figure you're using. You can't use V4's shoes on Jessi (or James, for that matter) without the use of something like Wardrobe Wizard.
A utility program bundled with later versions of Poser. It allows you to convert clothes made for one model to another.
Attached Link: Shoe Problem
Okay...so I got a shoe problem...problem putting on high heel shoes on my character. I'm use to boots and sneakers...but I'm having difficutly with high heel shoes. So with anyone with experience tell me what I'm well doing wrong...is there an upload I need to get to put the shoes on correctly?I'm using Poser 9 BTW...thanks.
