Thu, Jan 9, 11:41 PM CST
Subject: Using HDRI
timarender ( ) posted Thu, 19 January 2012 at 11:48 AM · edited Thu, 09 January 2025 at 11:10 PM
I am new to HDRI, but having tested a render Poser into Adobe's 'After Effects', I was astonished at how powerful HDRI is. Wow!
Even so, I am wondering whether HDRI is widely used by Poser Users. And if so, why? And are there any tips when rendering images intended for export as HDRI?
wimvdb ( ) posted Thu, 19 January 2012 at 12:18 PM
You can output an HDRI image in PoserPro 2010 and 2012
You can also use HDRI images as textures and as light probes in Image Base Lighting (IBL)
I am not sure what kind of tips you would like to see
timarender ( ) posted Thu, 19 January 2012 at 6:26 PM
Thank you for the reminder about using HDRI within Poser.
I was wondering whether anyone regularly rendered using HDRI for some purpose outiside of Poser. Given the options for modifying an HDRI image (using external apps), would it be better to render in a particular way? Perhaps by trying to avoid strong contrasting shades and to keep smooth shadows.
As far as I can see, there should be no reason to use an external app, but I am wondering whether it really may be easier to get a final desired result by using an external app; rather than relying entirely on Poser.
wimvdb ( ) posted Thu, 19 January 2012 at 7:03 PM · edited Thu, 19 January 2012 at 7:04 PM
HDRI images contain the full range of colors. But unfortunately there are no monitors which can display this complete range. You need an image editor which can read the complete range and allows you to define the selection you think your image needs. So effectively this is post processing.
In Poser Gamma Correction corrects the color to its true values. These values are used to make the material adjustments. So this takes care of the contrasting shades you mention. Saving these in HDRI gives you the full range of shades and colors which are present in the image.
Now with the full range you can use the image editor to pick the shades and colors which fit your interpretation of the image.
It is a really complicated thing to explain - search the web for colorspaces, color palettes and the 16, 32 and 64 bit color image file specifications and you will see the wide variety of choices you can make (or better - the limitations you run into)
I use a professional monitor which has a much larger color spectrum as a "normal" monitor and the difference can be dramatic. The same HDRI image just looks dull on consumer level monitor because less colors are displayed.
So concluding - Is it better to save in HDRI format? Yes, but you need to post process it to make it available for other users on a computer
