Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
"Oh - the manual says that? I have never read the manual - this must be why."----------------------------------------------------------------------------------------
"Oh - the manual says that? I have never read the manual - this must be why."Use my car paint shader on the nails. Painted nails are not a variation on skin. It's a completely different substance.
Quote - Use my car paint shader on the nails. Painted nails are not a variation on skin. It's a completely different substance.
DOH!! :blushing: I'd wondered about removing the skin map, but presumed that it was there for some improtant reason. The car shader was easy, as there is a car in the scene. I'm still not sure why the nails ended up white...
Thanx, All.
"Oh - the manual says that? I have never read the manual - this must be why."In most cases, nails are colored procedurally through the Mat Room. The EZShaper script does not take that into account, so it will ignore original setups and replace it with it's new set. And the EZShader set only uses clear nail polish settings. If you are using the XML to define which shaders to apply, then you can set ignore for the nails within the file for your particular character, and just use whatever other node structure relevant for your needs.
Hi Gang,
I just got around to trying EZSkin-what a great utility!!
However, I applied it to a V4 figure with red fingernails, and they render white. The diffuse colour is still set as red, and they are red in the preview. The tonails, which were left natural, render fine. I'm not sure which node to add the nail colour to to fix the fingernails.
Thanx in advance.
"Oh - the manual says that? I have never read the manual - this must be why."“I could buy better software, but then I'd have to be an artist and what's the point of that?"
