Tue, Oct 22, 12:33 AM CDT
Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
Subject: Open vob in vue10???
3eighty ( ) posted Fri, 27 January 2012 at 11:30 PM · edited Mon, 21 October 2024 at 10:34 PM
Souldn't Vue 10 be able to open an purchased vob from Cornacopia??  Even though it was before V10?
Thank You
ShawnDriscoll ( ) posted Sat, 28 January 2012 at 12:47 AM
Depends on the version of Vue 10 and on the error message you're getting.
Paula Sanders ( ) posted Sat, 28 January 2012 at 7:50 AM · edited Sat, 28 January 2012 at 7:50 AM
I use Vue 10 Infinite and vobs from many versions ago. Occasionally one won't work, but in the message usually states that it needs the conversion because it turns out to be a very old one.
3eighty ( ) posted Sat, 28 January 2012 at 2:52 PM
The only message I get is it can't read it?
ShawnDriscoll ( ) posted Sat, 28 January 2012 at 4:03 PM · edited Sat, 28 January 2012 at 4:10 PM
That means two things:
Your Vue is an older version or a weaker version than the one used to make the VOB/Vue file.
Or the VOB/Vue file is locked to an older version of Vue you had.
You can edit the download setting of the file on C3D, if you bought if from there, and tell it the exact Vue you have now and re-download the VOB/Vue file again.  It should load into Vue (if you have all the other stuff like plants that it needs, etc).
