Tue, Feb 18, 12:23 AM CST
Subject: 3D Obj - Numbers
TheBryster ( ) posted Sun, 29 January 2012 at 11:46 AM · edited Sat, 18 January 2025 at 10:18 AM
Does anyone have any numerals in Bryce or obj format?
I'm looking for models of the numbers 1, 2, & 3.
Appreciate any links if you have them of actualt objects.
Thanks for reading!
johnyf ( ) posted Sun, 29 January 2012 at 12:04 PM · edited Sun, 29 January 2012 at 12:05 PM
Attached Link: http://www.armanisoft.ch/webdesign/elefont/Elefont.html
Elefont is what you want. Creates most type faces and imports into Bryce as .dxf.
staigermanus ( ) posted Sun, 29 January 2012 at 12:18 PM
Any particular font? edge conditions?? Easy to make in Carrara with the text tool. Then export to OBJ after conversion to vertex object.  I think that should work. Let me try with the VErdana font.
-Philip
Ravyns ( ) posted Sun, 29 January 2012 at 12:21 PM · edited Sun, 29 January 2012 at 12:22 PM
I did these in Wings3d..
3 different fonts.. 1-Impact..  2-Arial Italic..  3- Sylfaen
It's very easy to get the numbers into Wings & they can be smoothed to look better then these.  Not sure how much fun doing the uv's for them would be tho'.
I can do them for you if you want..
Life may not be the party we hoped for but while we're here we should dance.
staigermanus ( ) posted Sun, 29 January 2012 at 12:30 PM · edited Sun, 29 January 2012 at 12:33 PM
See if this one works?
http://dl.dropbox.com/u/8120854/thebest3d/3dnumbers/1.obj
I used Carrara 6 Pro in this case (I have other versions on other computers). The OBJ header says C5 but it's C6. Anyway, used the Text tool in Carrara to insert the number 1 (one), using Verdana as the font, bevelled both front and back, and selected Bold style.
Then converted the object to another primitive type, choosing of course vertex object. Removed lights and camera from the scene and saved the whole as Wavefront .OBJ file. (without material). Even though it didn't appear to save the material file, it seems to map vertex texture (vt) coordinates into the file. SHouldn't hurt, and could be useful later if you add texture.
Let us know if you are able to use it as intended in Bryce?
I can make 2 and 3, if you can specify the desired font, style (bold, italic) and beveling preferences.
-Phlip
PS:
I enjoyed this little getaway, I've been playing with rotoscoping in Dogwaffle and morphing shape curves used for animated brush strokes. It's good to do 3D inbetween :-)
tjohn ( ) posted Sun, 29 January 2012 at 12:35 PM
You can do it in Bryce as well using a solid white pic of each number on a separate solid black background as the source for a Bryce lattice.
staigermanus ( ) posted Sun, 29 January 2012 at 12:52 PM
Here's an updated list of letters 1, 2 and 3, in OBJ format, VErdana, Bold, front and back beveled flat, triangulated.
http://dl.dropbox.com/u/8120854/thebest3d/3dnumbers/123-as-obj.zip
I hope this works for you.
-P
kiwi_gg ( ) posted Sun, 29 January 2012 at 1:07 PM
Photoshop and the terrain editor do it for me. Save as obj. Otherwise in B6.3 presets  create>object> signman set 2.
Cheers
GG
WHO said Kiwi's can't Fly ?????
TheBryster ( ) posted Sun, 29 January 2012 at 1:32 PM
I totally forgot about Elefont!!!
kiwi_gg ( ) posted Sun, 29 January 2012 at 1:41 PM
Quote - I totally forgot about Elefont!!!
Ahhh! senior moments, don't ya just luv'em ?????
Cheers
GG
TheBryster ( ) posted Sun, 29 January 2012 at 2:11 PM
THanks for all the suggestions, Guys!
IO4 ( ) posted Mon, 30 January 2012 at 1:32 PM
These are in the freebie section here..I think it's the pack I have (can't remember to be honest but it sounds like it)..I installed them into DAZ Studio, then I just import them via the Bridge.
http://www.renderosity.com/mod/freestuff/details.php?item_id=50131
Beginners tutorials for Bryce
Bryce Arena
karl.garnham1 ( ) posted Mon, 27 February 2012 at 12:53 PM
Do you still need these Numbers in Bryce? if so let me know and I will make you some in an .br6 file  or .obp if you are interested they would be made in Boolean form.
Cheers
Karl
TheBryster ( ) posted Tue, 28 February 2012 at 9:15 AM
Karl, thankyou, but I made some with Elefont.
You can the result by using the green Challenge Page Link at the top ofthe page.
Once again, thanks to everyone who posted replies here.
karl.garnham1 ( ) posted Tue, 28 February 2012 at 11:56 AM
Hi Bryster
Your Welcome if you or anyone needs something let me know
all the best
Karl
wheatpenny ( ) posted Tue, 28 February 2012 at 7:59 PM
Site Admin
Also, Hexagon can do 3d text from any font (as can most modeling programs). I just figured I'd mention that since Hexagon is now free for the time being.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
