Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
It would be a lot of work,you'd have to export everything as .obj, convert to povray with Poseray, render in povray with the no_image, then render just those elements you didn't want the image and layer them together. Second render would be with the no_shadow, obviously. But you'd have to export anything you wanted no-image as a separate .obj, time consuming to say the least.
D.
The "I" in Doric is Silent.
Medzinator, thank you!
How did people composite scenes before "Visible in Camera"? Fiddle the lighting and shadows in postwork? I guess they could have rendered just the shadows, then rendered the objects they wanted, separately, without shadows. But that seems clunky. The camera thing sounds ideal if it works, I can't wait to try it.
If I'm prepping a scene for later compositing PhotoShop, I'd like to be able to turn off the props for some shots but not change the lighting in those shots. In other words, when the props are invisible, light comes through and illuminates the figure full force. In the original base scene, some of the light is blocked. So the later, overlit renders look "pasted on" when layered onto the original scene with its original lighting and shadows. Any way around this in Poser? Make the light-blocking elements invisible while still blocking light?
