You could also LOCK the objects that hide the one you want to select. This would leave your object free for direct selection.
Ah... photosynthesis was faster than I. ;)
How to select hidden objects or such that a part of a group in Bryce:
Hubert
"All that we see or fear, is but a Sphere inside a Sphere." (E. A. Pryce -- Tuesday afternoon, 1845)
You can't boolean metaballs, Karl.
Bryster,
You can certainly use negative metaballs to cut away parts of positive metaballs, which is a boolean operation. And while you don't HAVE to group metaballs the way you have to group other objects to get them to boolean, you CAN group them if you want to control multiple sets of metaballs independently. You can't use the intersect boolean function on metaballs & you can't boolean them with other types of objects, but positive/negative works just fine. This may be what you meant, but I think it's misleading to just say "You can't boolean metaballs"...
"Every child is an artist.
The problem is how to remain an artist once we grow up."
Picasso
http://www.renderosity.com/mod/gallery/index.php?image_id=1551181&user_id=122226&np&np
Attached Link: Chaotic Order Mandala
Booleaning metaballs have worked I believe from the very first release in which metaballs were released or if not, shortly thereafter. Bryce 7 introduced the ability to create negative metaballs by just changing the attribute of a positive metaball to negative. Before that, you had to hold the Shift key down when first creating a metaball to make it negative.Using booleans with metaballs to model isn't as easy or straightforward as using other booleans only because negative metaballs exert a "gravitational" effect, just as positive metaballs do. So the size of a negative metaball & it's distance from the positive metaball it is subtracting from affect what happens. I don't do realistic modeling, but I think it would be very challenging to do so using metaball booleans (though I'm sure more patient & skillful Brycers than me have done it). But for the kind of abstract & surreal work I do, it works just fine.
The attached link is an example in which I've used booleaned metaballs. Those depressions in which the "eyeballs" are sitting are created by negative metaballs, as are the cutout areas of the egglike shapes right below them through which the tori runs.Here's a real simple way to validate this:
Open Bryce 7. Set the edit mode to Camera Space. Create a metaball. Just to make thing easier to see, make it larger & move it up above the ground plane (or just delete the ground plane). Then duplicate it. Both metaballs are positive at this point, so what you'll get is a larger metaball. Then change the second metaball's attribute to negative. This will make them both disappear, because they exactly cancel each other out. Next, make the negative metaball much smaller - say about a quarter of the size of the positive one. You'll see one metaball again. The negative metaball doesn't seem to have any effect, because it's INSIDE the positive metaball. Now very slowly move the negative metaball towards you, while watching the nano preview. You'll see it carve out a hollow depression. You can watch how it changes as you move it back & forth. If you change the size of the negative metaball, that will change things as well.
Hope that helps...
Picasso
The scenario is that I am working on a scene that contains some objects, and I decide to make some changes to one of them, a small object, but I can't select it as it is hidden behind (or inside) another larger object. Each time I try it's the large one that gets selected. I would hope that the answer is as simply holding down a key and them cycling through all the objects created. Or is that just TOO simple?
You wonderful people have never let me down in the past.
