Fri, Jan 10, 9:43 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Looking for a Tooth prop or object
danidh ( ) posted Fri, 10 February 2012 at 7:57 AM · edited Fri, 10 January 2025 at 7:15 PM
My youngest lost a tooth and is now requesting a tooth fairy image...has anyone run across a tooth prop or object that can be imported into Poser.  Thanks, Dani
Acadia ( ) posted Fri, 10 February 2012 at 1:24 PM
danidh ( ) posted Fri, 10 February 2012 at 3:00 PM
Thank you.  Wish Poser could use c4d files.
Acadia ( ) posted Fri, 10 February 2012 at 4:59 PM
Maybe you can get someone to convert it for you?  Don't we have a C4D forum here?
Or maybe you can contact the creator at Turbo Squid and ask if they can convert it to an .obj for you.
lmckenzie ( ) posted Fri, 10 February 2012 at 6:03 PM · edited Fri, 10 February 2012 at 6:07 PM
Try these. You'll have to import the model into Poser and then use the grouping tool to spawn props and then select the individual tooth you want and save it as an individual prop. Someone else can probably explain that process better than I can :-) You'll also have to create a texture - maybe just an slightly off white color would do for what you need.
I'm not sure what the difference is with the different .obj files is. I used the teeth_max.obj and that worked fine.
Hope the tooth fairy is generous!
Teeth: http://www.sharecg.com/v/57443/view/5/3D-Model/Teeth
danidh ( ) posted Sat, 11 February 2012 at 4:40 AM
Thank you!
ToxicWolf ( ) posted Sat, 11 February 2012 at 7:43 PM
I see you came up with a tooth. Love the picture you posted.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
shuy ( ) posted Sun, 12 February 2012 at 2:47 PM
Textured tooth with gums can be "extracted" with most poser figures.
Use grouping tool on head, crate new group add material "inner mouth" and "teeth".
You can either check glass next to bed.
Acadia ( ) posted Sun, 12 February 2012 at 4:11 PM
Attached Link: Quinn's Tooth Fairy
Oh my goodness!  What an adorable image!
lmckenzie ( ) posted Sun, 12 February 2012 at 9:18 PM
"What an adorable image!"
Indeed!* *
danidh ( ) posted Mon, 13 February 2012 at 2:35 AM
smile  Thank you.
