Yes to both, some of the windows open, some of the square ones, and yes the windows are a different material so the light can shine through. Because there are so many rooms though the first floor is one material, the second floor rooms are one material and the attic is one material, if you want wall paper you will have to use the map to create it. A texture map will also be included. Sharen
![file_206141.jpg](https://live.cdn.renderosity.com/forum/threads/389204/file_206141.jpg)
Here is a sneak peak of the haunted house...remember it is still in autocad stage so it looks kind of boring. I had to add the lights just so you could see more. You should see the inside. Hope you like. Sharen
