You will have to give more details- I unzip the files-they usually have a structure similar to what you should end up with in your own Runtime. If you go to Applications-you should find a subfolder of Pro called PoserPro2012 Content- inside that is Runtime. You drag and drop the items from the runtime from your download-into the appropriate folders. Then restart Poser. Your library has your files. If you drag and drop while it is already running-you need to refresh your folders in the Library window. Select the folder-then a little icon appaears on the right called Refresh.
If you still dont see it-you've likely put something in the wrong destination. Easy to do!
Or - this has happened before - you bought textures that are add-on products for things, but you don't actually have those things.
So I use a utility to merge my runtimes, but most of my stuff is in external runtimes anyway.
Love esther
I aim to update it about once a month. Oh, and it's free!
Hi,
I'm new in poser, I bought a lot of things from renderosity, I tryed to instal as is writen on poser page, but after that I couldn't find that figure in library. What is corect way to instal new stuff?
thanks
