Tue, Jan 7, 9:45 AM CST
Subject: if a=1 then b?
JAFO ( ) posted Sun, 19 February 2012 at 1:03 PM · edited Sun, 05 January 2025 at 9:25 PM
is there a method of rigging one parameter dial to another so the second dial is not editable unless the first dial has a value of 1? I'm very limited in knowledge of scripting , this may be already available in PP2012 and I'm just overlooking it... if not then it would be a very useful thing to have , the possibilities would be endless for such a command when using master parameters,
Thanks for your time...
:O)
JAFO
Y'all have a great day.
msg24_7 ( ) posted Sun, 19 February 2012 at 4:33 PM
It can be done by editing the file using ERC and / or using Poser's dependend parameters.
You may want to have a look at examples shown in Poser's manual.
They do explain it way better than I could :)
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
DarkEdge ( ) posted Sun, 19 February 2012 at 4:41 PM
Attached Link: DarkEdgeDesign.com
If you go to my website and select tutorials, then select the Making Props Into Figures tutorial I go over how to use Dependent Parameters. 😄
markschum ( ) posted Sun, 19 February 2012 at 5:59 PM
I dont know a way of doing what you asked with dependant parameters or erc. The slave parameter can be changed manually if it is left visible.
ockham ( ) posted Sun, 19 February 2012 at 6:32 PM · edited Sun, 19 February 2012 at 6:34 PM
You'd probably have to use a called python script to get an If-Then response.  Those have always been available but VERY rarely used.
Even with that, I'm not sure you could do what you want.  A called python can do a bunch of stuff at the moment when the prop or figure is located, but I don't know if you can make it hang around waiting for the user to move things.  (That would require using event callbacks, which are nasty!)  And after that, you'll have another problem making the callback go away when the figure is deleted.
For an example of doing stuff at load time, look at the "Gas-Harp" and "Sink-Pump" figures in my 1910 Kitchen.  Those would give you examples to build on.
http://www.sharecg.com/v/47345/gallery/11/Poser/1910-Kitchen
My python page
My ShareCG freebies
nruddock ( ) posted Sun, 19 February 2012 at 7:25 PM · edited Sun, 19 February 2012 at 7:26 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3752382&ebot_calc_page#message_3752382
Wouldn't using "valueOpTimes" be the appropriate thing for this.
When the master dial is 0, the slave dial final value will be 0 no matter what.
If the limits and trackingScale are set right, the master would act like a switch on the slave.
JAFO ( ) posted Mon, 20 February 2012 at 11:43 AM · edited Mon, 20 February 2012 at 11:47 AM
sorry for the delay getting back, i have contractors here i had get permits ... lota hassles.... anywho.... im not wanting to slave one peram dial to another , a rather simple process in PP2012, im trying to build branches for animation and lock out params that arent compatable with eachother, didnt mean to make a big fuss about this but, being new to pp2012, and the documentation doesnt cover everything i was wondering if this were a hidden feature i just didnt know of, i guess it isnt... i do apreciate your taking time to look at and consider this... your openion is important to me and i take your advice seriously, you guys are awesome in your collective knowledge...again
thank you
:O)
JAFO
