Two suggestions:
For Poser 7 on Windows 7 the INI and UI Prefs files are located at:
C:UsersUSER NAMEAppDataRoamingPoser 7
If you delete these files Poser will re-create them on launch.
Also, again using Poser 7, Edit menu, General Preferences select Launch to factory state. That should fix your problem without deleting the AppData files.
Best Wishes,
Rªnce
I think if you use menu Window/Document Window Size, you may be presented with a dialog saying that no sizing can be done while the window is docked and an option to float the preview window. Do that.
Once you have it floating you should be able to dock it back in a sensible way.
You may also find that the docking slider is just all the way to the left or to the right and if you grab over there you can put things back to normal.
![file_478716.jpg](https://live.cdn.renderosity.com/forum/threads/2844787/file_478716.jpg)
Somehow I have mananged to mess up my Materials editor UI and I can't find any reference on how to restore it to Initial state or fix it so I can see the windows I want to see.Right now the preview window won't float or doc at all into the materials tab.
I tried clicking on the UI dots, but they don't seem to do anything.
The manual and "help" text is not useful.
Edit - I attached a screenshot of my current materials ui
