Hi,
How do I disable keyframes?
I decided to use frames while making a series of images so I could easily go back and edit earlier pics if needed. The problem is I am now on the 5 frame/pic and I want to use a different pose. Poser sees this as a keyframe and adjusts the earlier frames which i don't want.
I tried google and searching the manual which suggested unchecking 'animating' under the main cameras properties which according to the manual should disable the auto creation of keyframes but it didn't :(
From the manual
Camera animation must be enabled for the currently selected camera In order to automatically record keyframes. If animation is disabled, you can add keyframes manually (see following subsection).
