Wed, Jan 22, 5:35 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 2:19 pm)
Subject: Correct Reference?
Terry Mitchell ( ) posted Tue, 21 February 2012 at 2:52 PM · edited Sun, 22 December 2024 at 8:07 PM
There use to be a product for older versions of Poser called Correct Reference (by Hogsoft, I believe) that would fix things up so Poser would be able to find textures and other files associated with library models easier and faster and not hang.  Does something similar exist for Poser Pro 2012 or is it not necessary because the newer versions of Poser doesn't have the library problems of the older versions?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
MacMyers ( ) posted Tue, 21 February 2012 at 3:45 PM · edited Tue, 21 February 2012 at 3:46 PM
They still make it... but it won't work with PP 2012 under Win 7.
CR Pro "should work" without the Win 7 Problems according to Howard
"I haven’t tested it with PP 2012 – it is only tested fully up to Poser 7 which to all intents and purposes is the same as Poser 5 in file structure.
CRPro is fully conversant with node shading (Poser5+), morph injection and pmd files. I am sure that there have been few additions to the Poser file structure, especially when referenced external files, since then… You can be sure that CRPro will still fix all texture/geometry/pmd/injection references correctly!"
I haven't tried it yet.
            “So, roll me further B_t__h!”
