Sun, Jan 12, 12:50 AM CST
Subject: Weight map on hip ?
davedoo ( ) posted Wed, 22 February 2012 at 6:07 AM · edited Thu, 09 January 2025 at 12:51 PM
Hi, I'm using weight map,  painting the thigh and try to select the "hip" for the affected actors, and found out the hip is not selectable , there is no "check box " for the hip.
is there a way that it can be a "affector actor" for use in weight painting ?
TKS !
PhilC ( ) posted Wed, 22 February 2012 at 7:40 AM
The parent actor is included by default.
davedoo ( ) posted Wed, 22 February 2012 at 7:47 AM
Hi Philc, does it mean weight map will not work on parent object ?
Thanks
PhilC ( ) posted Wed, 22 February 2012 at 7:57 AM
The weight map will work on the parent object if you set it (paint it) to do so. If your edits do not appear to be effective check your Joint Editor settings.
