Thu, Jan 30, 6:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 4:51 pm)
Subject: How do you make Victoria 4.2 work with Poser 9?
gohanf22 ( ) posted Thu, 01 March 2012 at 12:20 PM · edited Mon, 27 January 2025 at 10:49 PM
Ok so I have been trying to get help on how to make Victoria 4.2 work with Poser 9.  I installed it like any other thing and when I opened Poser 9 I can't find it in the library.  Did I do something wrong?  Please help.
SamTherapy ( ) posted Thu, 01 March 2012 at 12:23 PM
What's your OS?  If it's later than XP did you disable UAC and install V4 to the correct directory?  Have you run the Initialize script that comes with V4 and are instructed to use?
gohanf22 ( ) posted Thu, 01 March 2012 at 12:30 PM
Quote - What's your OS?  If it's later than XP did you disable UAC and install V4 to the correct directory?  Have you run the Initialize script that comes with V4 and are instructed to use?
I have windows 7 x64.  I installed V4 to the Poser directory I am using.  Was I supposed to install it somewhere else?  And I didnt know I had to disable UAC in order to install it right.  Also, yes I did do the initialize script at end of installation.
gohanf22 ( ) posted Thu, 01 March 2012 at 12:57 PM
Ok I did actually have UAC disabled when I installed it.  I'm just not sure what I did wrong why it won't come up in the library on Poser 9.
LaurieA ( ) posted Thu, 01 March 2012 at 1:09 PM · edited Thu, 01 March 2012 at 1:11 PM
IF you have Poser installed in the Program Files directory and IF  you installed Vicky to the runtime inside the Poser directory in Program Files, they will NOT show up in your library. UAC will not allow anything to be written to any folder in Program Files.
There are soooooo many threads on this here at Renderosity - do a site search and check some of them out.
gohanf22 ( ) posted Thu, 01 March 2012 at 1:25 PM
Lol I solved it on my own. When I did the shared folder part of installation, I forgot to choose the bottom choice for if you have low HD room on default drive.  It's fixed. lol.
