Just install Poser 7 into its own directory , and add you Poser 4 runtime as an external runtime, and they should happily coexist and you can use your existing content in Poser 7...
To do this, open Poser 7, and hop to step 4 in this tutorial...
http://www.posermocap.com/2008/09/16/tutorial-setting-up-multiple-external-runtimes/
"Oh - the manual says that? I have never read the manual - this must be why."Quote - out of curiosity, what OS are you using where poser 4 still works? cuz mine croaked :/
I'm using Windows XP. Poser 4 runs fine, it's just too much of an antique to run higher level files. I should have upgraded it years ago, or just made the switch to newer versions of Poser. I have to say that I find Poser 7 to be cumbersome, and needlessly complex. I guess that's why I feel so comfortable with 4 and hate to say goodbye to it. Thanks to all of you for the help. I'll try to digest the insightful information you have given me. Again, thank you very much.
Be prepared for a wee learning curve: give yourself a bit of time, and you will be rewarded with a significantly improved Poser experience. Poser 7 is my favourite non-Pro (as in: Poser Pro, Poser Pro 2010, Poser Pro 2012) version. It is rock stable and ran really well on most systems.
You won't be upgrading Poser 4. You will be running Poser 7 as a uniquely different piece of software to Poser 4, but you should be able to use all of your content as before, with a few caveats mentioned Sharen and WandW.
Well, I'm almost embarrassed to ask this question as Poser 4 is such a relic. However, I am very comfortable with it and like the simplicity as my use is to aid my graphic art projects.
My question is; can I upgrade Poser 4 with a new Poser 7 package I recently bought. (i.e. make the operating system of Poser 4 more current so it will use higher Poser programs).
These are my concerns:
Will doing this bring Poser 4 up to a higher level like Poser 5 status?
Will this risk wiping out my library of poses, props, and figures with morphs?
Should I put everying on a memory storage device before attempting this?
There are probably other things but I'm such a neophyte and need things dumbed down. I apologize if this is just too moronic to address. Regardless, I would appreciate the advice.
