Fri, Nov 22, 12:48 PM CST
Renderosity Forums / Suggestion Box
Welcome to the Suggestion Box Forum
Forum Moderators: msansing
Suggestion Box F.A.Q (Last Updated: 2024 Nov 17 10:06 am)
This forum is designed for suggestions from the community on how you feel we can improve Renderosity.
Subject: Marketplace broken in Opera
Andrew_C ( ) posted Sun, 18 March 2012 at 9:44 AM · edited Fri, 22 November 2024 at 12:41 PM
Just started using Opera again (11.61) and the Renderosity Marketplace is broken in Opera. When you visit a product page, the entire page appears twice and links don't appear to work (have to navigate out using browser back button).
Basically the Marketplace is unusable. The rest of the site, Forums, Tutorials, freebies, Galleries, Account Page and even Wishlist works fine. Just the marketplace is broken.
 It used to work fine, I haven't used Opera regularly for a couple of years but it used to be my main browser and all of Renderosity worked fine in Opera. It was one of the sites I could count on to work.
 Perhaps it has something to do with your last redesign? Like I said haven't used Opera for a while, so only just noticed this.
 EDIT: only product pages affected, Marketplace front page works fine.
Jumpstartme2 ( ) posted Sun, 18 March 2012 at 1:14 PM
Im using the exact same browser and version, and Im not having any problems at all in the MP.
Have you changed anything like the CSS for Rendo?
~Jani
Renderosity Community Admin
Andrew_C ( ) posted Sun, 18 March 2012 at 4:07 PM · edited Sun, 18 March 2012 at 4:17 PM
Nope, strange, not using custom css and using standard Opera settings. I'll try deleting my operapres.ini and see if that helps. That ocassionally gets corrupted and causes problems.
EDIT: Looks like that was the problem - haven't had to do that in ages, so i didn't think of it (back when operaprefs.ini was called opera6.ini).
Jumpstartme2 ( ) posted Mon, 19 March 2012 at 5:34 AM
Good to hear you got it worked out...I'll file that bit of info away for myself too..only where is the .ini? :D
~Jani
Andrew_C ( ) posted Tue, 20 March 2012 at 9:30 AM
on Win7 it's under C:UsersAppDataRoamingOperaOpera , so it will probably be under C:Documents and SettingsApplication DataOperaOpera on WinXP.  on Linux its under /home//.opera/ no idea where it is on OSX, though
Jumpstartme2 ( ) posted Tue, 20 March 2012 at 6:58 PM
Thankies!
~Jani
