Sat, Feb 1, 5:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Subject: Having an issue with Anastasia Clothing
EClark1894 ( ) posted Wed, 28 March 2012 at 10:54 AM · edited Sat, 01 February 2025 at 5:02 PM
Actually, I've had this problem before, but I'm hoping someone can give me some hints or tips about how or what to do to correct it.
I'm modelling a bodysuit for Anastasia. I'll have to figure out morphs later since I can't use the Morphing Clothes utility. (I'm on a Mac). Any way, here's a screen shot of the bodysuit in Blender.
As you can see, I'm modeling using the Anastasia morph and the figure is Zeroed.
EClark1894 ( ) posted Wed, 28 March 2012 at 10:57 AM · edited Wed, 28 March 2012 at 11:01 AM
Now here's a screen shot of the suit in Poser after I've run it thru the Setup Room.
As you can see, if I try to conform the suit to Anastasia, the legs don't quite conform right.
Any answers what's gone wrong?
EClark1894 ( ) posted Wed, 28 March 2012 at 11:03 AM · edited Wed, 28 March 2012 at 11:03 AM
One more thing, I can zero the suit and get it to conform with a little fiddling, but then I get a WHOLE lot of poke thrus when the arms and legs bend. What's going on there?
MarianneR ( ) posted Wed, 28 March 2012 at 11:22 AM
First question. Look in this thread:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3887180&ebot_calc_page#message_3887180
Second question. That is probably the JCM's in Anastasia.
PhilC ( ) posted Wed, 28 March 2012 at 11:23 AM · edited Wed, 28 March 2012 at 11:24 AM
  1. After zeroing the suit go to Edit > Memorize > Figure. This will remove the preset bends that are throwing you out. May not be required because you'll also be doing (2) but it will not hurt any.
  2. Anastasia is weight mapped. To get that info into the suit go to Figure > Copy Joint Zones from...
Hope that helps.
EClark1894 ( ) posted Wed, 28 March 2012 at 11:30 AM
Sounds good Thanks to you both.
