Sun, Feb 16, 9:42 PM CST
Subject: Victoria 4 renders incorrectly in Poser
niserin ( ) posted Wed, 28 March 2012 at 11:40 AM · edited Sun, 16 February 2025 at 7:29 PM
In addition I used the Elite textures on her and EnvSphere from BB and one regular spot light + indirect light in PP 2012.
What are those black dusts and dirts on her ? Btw, the problem only occurs when I render to 5000x5000. In an initial small preview render, everything seemed to be ok.
Secondly, what render setting should I use to optimize the picture for such a huge resolution ? I mean to get the most from the Elite textures.
Thanks,
Michal
LaurieA ( ) posted Wed, 28 March 2012 at 12:13 PM · edited Wed, 28 March 2012 at 12:15 PM
What is your shadow min bias? Set it low - 0.10000. Also looks like you might have AO turned on somewhere, either in the materials or in the lights. You don't need AO with IDL.
You also have a more than one light with the Envirosphere. I wouldn't recommend that. Also check to see you have ray traced shadows and not depth mapped.
That's all I can think of.
niserin ( ) posted Wed, 28 March 2012 at 12:34 PM
Yep, I have AO in materials enabled, that's my mistake...
Shadow min bias is set to 0.5. Is there a need to lower it down so much ?
WandW ( ) posted Wed, 28 March 2012 at 1:09 PM
It depends on what your units are.  That's pretty high if your units are feet...
hborre ( ) posted Wed, 28 March 2012 at 3:11 PM
For inches, BB had been recommending 0.1.  And if you are using the Envsphere without any textures, you could forego any additional lighting.
bagginsbill ( ) posted Wed, 28 March 2012 at 5:09 PM · edited Wed, 28 March 2012 at 5:10 PM
Hang on - while I'm showing lots of renders without lights, many people don't know how to use reflection to get back the specularity.
It's perfectly valid to use lights, especially specular-only lights, to make specular nodes work. (Blinn, Glossy, Specular, Anistropic, ks_microfacet, etc.)
If you want to go no lights, you gotta totally go over everything that has any shine at all and add Fresnel_Blend + Reflect nodes and set the Reflect softness correctly.
When done right, no lights are needed.
This is a no-light render. Observe the TV reflected on the figure.
bagginsbill ( ) posted Wed, 28 March 2012 at 5:12 PM
This is a render with a light and using the anisotropic node for the cloth. If you try this material with no lights it will not look good.
bagginsbill ( ) posted Wed, 28 March 2012 at 5:15 PM
No lights here. All three surfaces use Reflect and the Fresnel effect to handle specular - which then comes from the EnvSphere.
niserin ( ) posted Wed, 28 March 2012 at 5:49 PM
Quote - No lights here. All three surfaces use Reflect and the Fresnel effect to handle specular - which then comes from the EnvSphere.
Wow! Is there any specific tutorial on how to achieve this thing step by step ?
BTW, a beautiful render of the man in your first post. Where do you have these high res textures from ?
Cheers,
Michal
SamTherapy ( ) posted Wed, 28 March 2012 at 6:55 PM
BB - those renders are absolutely amazing.  You sir, are a true genius.
monkeycloud ( ) posted Thu, 29 March 2012 at 7:25 AM
Amazing stuff! Some real magic there Bagginsbill...
So adding specular lights, as opposed to no lights, sounds much quicker to do than going through and adding / tweaking nodes?
Would there be any noticeable benefit to doing the latter over the former?
Also, when I have no lights, or minimal lights my OpenGL preview is either entirely black or very dark... respectively.
Is this normal? Or am I just being a big newbie and missing something?
JAFO ( ) posted Thu, 29 March 2012 at 7:36 AM
comparing my renders to BB's renders makes me wana hide under a rock...
:O)
Y'all have a great day.
vilters ( ) posted Thu, 29 March 2012 at 8:05 AM
:-), am gonna rent a submarine to dive for cover.
I wish I could send a trainload of "time" to BB. Extra time to teach.
(and a cake and some flowers to his wife to let him teach). :-))
The problem , as usual, is that all his valuable info get so disperced over hundreds of posts. :-(
No way to keep up.
niserin ( ) posted Thu, 29 March 2012 at 9:29 AM
He definitely should write a tutotorial book or something.
By the way, if Smith Micro headhunted him, they would make one of the best deals in their business.
A huge talent.
LaurieA ( ) posted Thu, 29 March 2012 at 10:02 AM
Quote - By the way, if Smith Micro headhunted him, they would make one of the best deals in their business.
I think they have :P
hborre ( ) posted Thu, 29 March 2012 at 10:53 AM
Quote - Also, when I have no lights, or minimal lights my OpenGL preview is either entirely black or very dark... respectively.
Just for preview, use an infinite light and change the diffuse_color and specular_color chip to black.  That will give you plenty of preview lighting and will not render.
WandW ( ) posted Thu, 29 March 2012 at 10:55 AM
Quote - By the way, if Smith Micro headhunted him, they would make one of the best deals in their business.  A huge talent.
He wrote the Poser Library interface, and did the skin shaders for Miki 3... 😉
niserin ( ) posted Thu, 29 March 2012 at 10:58 AM
Oh, I wasn't aware of that ;). Still new here.
monkeycloud ( ) posted Thu, 29 March 2012 at 11:01 AM
Quote - > Quote - Also, when I have no lights, or minimal lights my OpenGL preview is either entirely black or very dark... respectively.
Aha - I see! thanks ;-)
Daymond42 ( ) posted Fri, 30 March 2012 at 10:07 AM
I still feel that someone needs to tap into BB's brain so we can his arcane arts at things and produce a book on it. :D
..... okay, it'd likely be a volume of books rivalling the now-no-longer-printed Encyclopedia Brittanica.... but still. :D
Now that I finally have time to explore my PP2012 that I'd gotten from the launch date, all these fun IDL threads of BB's can finally start to make sense to me!
Currently using Poser Pro 2012 (Display Units = feet)
AMD Phenom II 3.2ghz (6 cores)
8gb RAM
Windows 10 Pro 64bit
hborre ( ) posted Fri, 30 March 2012 at 11:12 AM
BB is/was in the process of writing a book.  But it may need to be pushed back in light of PP2012 release.
