Sun, Jan 26, 11:16 PM CST
Subject: item within an item
Mysted ( ) posted Thu, 30 August 2001 at 8:58 PM · edited Fri, 24 January 2025 at 5:42 AM
Is there a way to open a list of the created parts of a render? I have an inverted terrain with a water plane which I moved down to create a lake effect. Now I can't click on the plane to move or change it as it's within the terrain. I am using Bryce5. Thanks, Myst~
Wadus ( ) posted Thu, 30 August 2001 at 9:13 PM
the icons at the bottom of the screen lets you pick objects of a certail type like, picking all spheres or all planes, its down there where the animation controls are...
Mysted ( ) posted Thu, 30 August 2001 at 9:40 PM
I see what you're referring too. Thanks! I haven't had this program very long.
grumblecat ( ) posted Thu, 30 August 2001 at 10:27 PM
If you are on a PC you can also hold down the control key and right click over the object. This should bring up a context menu listing all of the objects under your cursor.
hewsan ( ) posted Fri, 31 August 2001 at 12:51 AM
tapping the tab key walks you through all the items in the scene - takes a while if the scene is busy though...
Mysted ( ) posted Fri, 31 August 2001 at 7:32 AM
Thanks! Myst~
HomerForPrez ( ) posted Fri, 31 August 2001 at 10:29 AM
Like Grumblecat said...the easiest thing is to just hold down the control key and then left (or right I guess) click on the lake...a dropdown list will appear and any object under it will be on the list.
