Fri, Nov 22, 8:45 PM CST
Subject: If someone could help me find something...
gold_star_ratings ( ) posted Fri, 31 August 2001 at 2:30 PM ยท edited Fri, 22 November 2024 at 4:33 PM
Hi all, I'm having a little trouble finding spiked hair for a character I'm trying to make. I have gone to countless places and have found one thing and that is here. Only thing is that when I try to use that hair in Poser, it's invisible. When I play around with the knobs to the left, I can see white dots outlining it, but the hair never shows up. If someone could point me in the direction of spiked hair, or if someone could even tell me what is wrong with the pack I have, I would greatly appreciate it :-)
Kelderek ( ) posted Fri, 31 August 2001 at 2:37 PM
The dots you see indicates that there is a transparency map attached to the hair. The hair will look normal when you render it. If you need to see the hair while working with the posing, you can open the Materials dialogue and set the "Transparency Max" slider to 0. then it will be visable. Don't forget to adjust it back to it's former value before you render, though!
gold_star_ratings ( ) posted Fri, 31 August 2001 at 2:41 PM
Okay, thanks for the info! :-)
